Thread: P0420 code
Results 1 to 9 of 9
  1. #1 P0420 code
    Feb 2009
    Howland, Ohio
    I have a 2002 Grand Prix with a 3.1L engine. Recently the check engine light came on. I went to Auto Zone and they pulled the codes. It came up with a P0420 code. The guy at Auto Zone said that the problem was probably an O2 sensor.
    The car smells of gas when sitting at idle but it doesn't run bad. I haven't noticed a lack of power but the gas milage has dropped quite a bit. Will a bad O2 sensor cause it to run very rich?
    I read through all the posts (all 57 pages of them) but I couldn't find any with similar problems. Does anyone have any other idea's or should I replace the O2 sensor and go from there?
    Any help would be appriciated.
  2. #2 Re: P0420 code
    TDCRacing
    Guest
    You're catalitic converter is going out and more than likley getting clogged up.
    You can do three things.
    1. Ignore it.
    2. Replace the cat
    3. Replace the cat with an off road downpipe (bolt in or weld in) wich will give you a little performance. That is if you don't have emmissions. You can get one from ZZPerformance and would more than likley be just as much as a new cat.
  3. #3 Re: P0420 code
    Feb 2009
    Howland, Ohio
    I thought of the cat, but the car only has a little over 60,000 miles on it. That's why I was thinking that the problem was somewhere else and not the cat.
  4. #4 Re: P0420 code
    SE Level Member coolken84's Avatar
    Apr 2008
    I had the same code on my 2001 3.8 and replacing the O2 sensor cleared the ses light. Not sure about the impact on mileage yet as I haven't ran through a tank of gas yet.
  5. #5 Re: P0420 code
    Feb 2009
    Howland, Ohio
    Thanks for the answers. From what I've heard a bad O2 sensor can cause the engine to run rich. This would explain the gas smell and the bad milage. I think I'll try an O2 sensor and see if that solves the probem. I'll let you know if it solves it.
  6. #6 Re: P0420 code
    Feb 2009
    Howland, Ohio
    I replaced the O2 sensor yesterday and that seems to have been the problem. No more gas smell and the code hasn't come back. I'll post again if it turns out that wasn't the problem.
  7. #7 Re: P0420 code
    TDCRacing
    Guest
    If that 02 sensor was bad you more than likley would have gotten an 02 sensor code. Not saying it can't happen but I have never seen or heard about that code associated with a bad cat o2 sensor.
    That o2 sensor does not contral any fueling. Al it's there for is to monitor the cat. That is it.
    In the PCM there is a table called CAT over temp protection. When you reach a certain engine temp via the ECT then it commands a richer AFR ratio. All the way down to 9.12 wich is extreamly rich.
    This may have been what you were smelling.
  8. #8 Re: P0420 code
    Oct 2012
    Seattle
    Are those sensors easy to replace on your own?. I paid a damn shop 300 to change one and now they said oh we think the other one is bad too.
  9. #9 Re: P0420 code
    Why resurrect an old thread and try to hijack it? Why not just make a new one?
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. code p0742
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2009, 02:16 AM
  3. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
  4. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
