Thread: another kr issue
Results 1 to 11 of 11
  1. #1 another kr issue
    Donating Users
    Plainfield, IL
    ok so i have adjusted the BBV 20+ times to try to fix burst knock...turns out no matter what i do i have at least 2.7 degrees of KR at WOT and high rpms...now today i noticed it his 9.3 out of no where but if i was really getting that much knock wouldnt i have felt it bogging like a champ...now two things..i talked to turbo tim at zzp and he said platinum plugs are terrible for knock reduction use copper? any body running platinum plugs without issues? and do you think that random 9.3 was false or are my plugs fouling out and causing excess knock?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: another kr issue
    TDCRacing
    Guest
    It could be false. Only real way to tell is to take timing out of that area to see if it goes away
    Copper plugs is what you should be running.
  3. #3 Re: another kr issue
    i am having a burst knock issue on my car. it knocks a lot when i start to boost, then fades out as the RPMs go up. if youre getting knock that increases as the RPMs go up then it is not burst knock or caused by the BBV.
    you should also be running copper plugs.
  4. #4 Re: another kr issue
    Donating Users
    Plainfield, IL
    hey guys i noticed i have excessive knock at high speeds say i do a 0-100 pull i see 1.9/2.1 then around 65mph to 100 ill see spikes of 6,7,8,9 sometimes...wtf is that? i can feel it studdering too so i know its real....
  5. #5 Re: another kr issue
    TDCRacing
    Guest
    Quote Originally Posted by iamwhutiam003 View Post
    Could also be TM
  6. #6 Re: another kr issue
    Donating Users
    Plainfield, IL
    Quote Originally Posted by TDCRacing View Post
    Could also be TM
    what is tm?
  7. #7 Re: another kr issue
    TDCRacing
    Guest
    what is tm?
    What Nick said. All automatic cars have it.
  8. #8 Re: another kr issue
    excessive load at high speeds will cause knock. also, the car runs leaner and leaner each gear it makes it through.
  9. #9 Re: another kr issue
    Donating Users
    Plainfield, IL
    ok wow found the problem....i had up to 8*kr when i was running ap104's (platinum) i just switched to AL104's (copper) and i side gapped them to preven fouling and i did 4 0-110 pulls and i never saw anything higher than 2.4*kr what a difference! dont run PLATINUMS PLUGS THEY SUCK ...got a catless downpipe in the mail im hoping for 0.0 kr after install!
  10. #10 Re: another kr issue
    torque management. it cuts timing (KR) when it sees a high torque level.
  11. #11 Re: another kr issue
    cant wait to turn that crap off so i dont get 9* of knock on a downshift into boost.
  1. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  2. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  3. I have an issue I cannot seem to figure out...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-31-2008, 02:06 AM
  4. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
