gaskets, spark plugs, thermostat, timing chain and tensioner...anything that you see when youre in the engine.
why are you buying the wiring harness? you dont need it. you just need one connector for the new MAP sensor that you need to run. the BBV on the blower can be left disconnected from the PCM without any negative effects.
