Thread: P0341 OBD-2 code
Results 1 to 4 of 4
Threaded View
icolex1 P0341 OBD-2 code 02-22-2009, 08:42 PM
Guest Re: P0341 OBD-2 code 02-22-2009, 09:00 PM
icolex1 Re: P0341 OBD-2 code 02-22-2009, 10:16 PM
Guest Re: P0341 OBD-2 code 02-22-2009, 10:19 PM
  1. #1 P0341 OBD-2 code
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    Just finished a complete top end rebuild on the '02 3800 GP. Got rid of the Dex-cool Hooked up the OBD scanner and had the P0341 code come up. It says it's "Camshaft Position Sensor A-Bank 1 CKT Range/ perf.
    Any one got a clue what in the heck that one is??
    I found the answer!!!!! Sometimes when the camshaft sensor wiring harness is mistakenly routed across the top of the coil pack/plug wires it will interfere and cause this error code. Some idiot was in such a hurry to put the top end back together he forgot which way it went (could have been me!!!) I did find it here though.Thanks for all you guys that helped!
    http://www.obd-codes.com/p0341
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. p0121 code
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2010, 10:13 PM
  3. P0102 code help!!
    By boostjunky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 09:50 PM
  4. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
  5. paint code
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 04-13-2008, 08:41 PM
