Thread: key fob help
Results 1 to 9 of 9
kaosGP97 key fob help 02-18-2009, 08:24 PM
kaosGP97 Re: key fob help 02-20-2009, 12:28 PM
Blown97 Re: key fob help 02-22-2009, 01:47 PM
kaosGP97 Re: key fob help 02-22-2009, 08:47 PM
Blown97 Re: key fob help 02-23-2009, 03:20 AM
kaosGP97 Re: key fob help 02-24-2009, 03:12 AM
Blown97 Re: key fob help 02-25-2009, 01:14 AM
GTX Re: key fob help 02-25-2009, 08:14 PM
dmontgom Re: key fob help 04-13-2009, 04:16 PM
  1. #1 key fob help
    SE Level Member kaosGP97's Avatar
    Oct 2008
    PA
    i recently bought a used key fob for my 97 gp and i tried programing it to my car and it worked for a little bit like a minute now it doesn't acknowledge it all i put a new battery in today and still nothing thanks for any help
  2. #2 Re: key fob help
    Oct 2008
    PA
    i know the receiver is behind the dic but is there any more modules that go with a key fob
  3. #3 Re: key fob help
    Feb 2008
    I would try reprogramming it again.
  4. #4 Re: key fob help
    Oct 2008
    PA
    i tried a couple of times and still no luck
  5. #5 Re: key fob help
    Feb 2008
    Key Fob programming instructions
    Key less Remote programing
    Not sure how you are doing your programming, so follow these.
    IMPORTANT: Before entering programming mode, have in possession all of the remotes you
    will be useing on the vehicle. Once you program the remote. all previous remotes that were
    programmed will be erased from memory. The other remotes will not be functional until you
    program the them again.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    owner's manual to properly locate the "MALL PGM" fuse.
    (passenger side, accessed through the glove compartment)
    4. Insert the key into the ignition, and turn to the ACC position. (back)
    5. Turn the key to OFF and then back to ACC within 1 second.
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    programming mode.
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    synchronization. It is necessary to wait approximately 14 seconds for a second chime
    that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
    If that doesn't work, I would check the Mall PGM fuse. If that doesn't do it you might have a problem with the transmitter or the receiver unit.
    Good luck!!
  6. #6 Re: key fob help
    Oct 2008
    PA
    i did all that, now i just have the trunk button working i called a pontiac dealership and they said some times they need programed with a scan tool
  7. #7 Re: key fob help
    Feb 2008
    Quote Originally Posted by kaosGP97 View Post
    ((((((WARNING))))))) BS STEALERSHIP ALERT!!!
    Imagine that, a deal told you that "sometimes" the need to do it with a scan tool. This is incorrect.
    I no longer think that this is not a programming issue, of course I'm trusting that you did the programming right. However, let me get back to you, there might be other programming that might need to be done. Ill let you know in the next day or so.
    Oh yeah, don't take it to a dealer!
  8. #8 Re: key fob help
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    97-03 gp's dont require the dealership tech 2 scanner for programming. sounds like your fob is broken
    COMP G
  9. #9 Re: key fob help
    SE Level Member dmontgom's Avatar
    Massachusetts
    Ok, I must be blind, but I can't find a way to thank Blown97, so I'm gonna just say it. I came across this thread after I got my remotes for my 01 GTP, and the info above was a huge help. So, thanks!
fob, key
