Thread: 2007 Grand Prix GXP Steering stiffen warm help needed
Results 1 to 3 of 3
  1. #1 2007 Grand Prix GXP Steering stiffen warm help needed
    SE Level Member Cbierniat24's Avatar
    Mi
    07 GP GXP losing power steering once warm at stand still/idle parking speed. Pump, rack, or ABS module?
    6K miles prior to current issue I replaced/serviced:
    Abs module was rebuilt due to internal malfunction. Fixed dash lights.
    Replaced OEM 250K rack and low/high lines due to leaks and rack wander. Low pressure line did not include a finned cooler. Leaks eliminated and steering restored with no dash lights. Resolved steering angle sensor code too.
    6 months after I replaced the rack, the operating temp stiff steering issue happened. Removed reservoir and cleaned out screen with brake cleaner. Also replaced hose reservoir to pump- Same issue
    Replaced OEM 255k power steering pump with reman- Same issue
    Replaced rack again due to rack whine and clunk- Same issue
    Fluid was flushed from return line and bled with tires in the air engine off and engine on everytime.
    Could the lack of a cooler on low pressure line cause the issue?
    Could a defective rebuilt ABS module cause the issue and not throw codes?
  2. #2 Re: 2007 Grand Prix GXP Steering stiffen warm help needed
    St. Louis
    The ABS shouldn't cause you to loose power assist. When you replaced everything did you bleed the air out of the system? This sounds like a bad pump to me.
    If you 2-foot it (brake and gas pedals) and raise the RPM's a bit when parking does the assist come back?
  3. #3 Re: 2007 Grand Prix GXP Steering stiffen warm help needed
    Mi
    Fluid was bled the old fashion way. No vacuum pump.
    I will try what you mentioned and update Sunday. It is not my car.
    Saturday its getting a new radiator, hoses, and Tstat. Im also adding a PS and transmission cooler.
  1. 2007 Grand Prix GXP lack of power steering when warm at stand still
    By Cbierniat24 in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2024, 12:54 AM
  2. 2007 Grand Prix stalls after warm start
    By lawadm1 in forum General Grand Prix Discussion
    Last Post: 01-18-2014, 11:06 PM
  3. 2007 Grand Prix GXP Steering Box
    By WkDcLwNz in forum General Grand Prix Discussion
    Last Post: 11-12-2012, 02:12 PM
  4. Whats needed for a top swap on a 2007 pontiac grand prix
    By cleaningman94 in forum General Grand Prix Discussion
    Last Post: 09-04-2012, 02:09 AM
  5. 99' Grand Prix 3.8L stalling out when it gets warm
    By Michelleb76 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 04:28 PM
