Thread: 4T65E Rebuild
Results 1 to 2 of 2
  1. #1 4T65E Rebuild
    Jun 2018
    Schweiz
    Hi all
    I will rebuild my transmission to a HD.
    I have a question for the inputshaft.
    There you have some teflon sealing rings.
    How can you remove the rings from the original inputshaft and how to install them on the new one?
    ​thanks for your answers
  2. #2 Re: 4T65E Rebuild
    Mar 2014
    Tucson
    Quote Originally Posted by kappa67 View Post
    There you have some teflon sealing rings. How can you remove the rings from the original inputshaft
    Razor blade or pick. They will get destroyed when removing, which is fine since they should not be reused.
    Use the proper installation and re-sizing tools.
    Short of that; Take your NEW rings and work them on to the shaft with a pick and some petroleum jelly. To re-size them, use a thin piece of plastic (like a file folder) as a buffer with cable ties or hose clamp. Just be careful not to crease the ring. Final sizing will be done when you jam the shaft into the mating components.
    Buy new rings
    175K Ring Kit (4T60E) (For L98-99, also sell 2 of 84179AT).......................................... .. 1 91-99 84175E N.L.
    175K Ring Kit (4T65E) (For 97-E98, also sell 84179KT) .................................................. 1 L98-Up 84175G N.L.
    175K Ring Kit, 2nd Clutch (2 Vespel Rings & 2 Rubber Expanders) ................................ 1 91-E98 84179KT N.L.
    ​179B 2nd Clutch (4T65E) (.100” Wide Plastic) .................................................. ............... 1 L98-Up 84179AT 24209498
  1. 4t65e rebuild 98 gp gt
    By mjsmith08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2019, 02:31 PM
  2. 4T65E rebuild DVD!!
    By chrisb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-05-2017, 01:54 PM
  3. 4T65E rebuild questions
    By 2000S80T6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2014, 08:49 AM
  4. 4t65e HD OK after GM rebuild?
    By payne335 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-16-2013, 03:43 PM
  5. 4t65e rebuild...
    By MontyJ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2012, 02:52 AM
