Thread: Suspension Suggestions
Results 1 to 6 of 6
  1. #1 Suspension Suggestions
    Canada
    I've broken a spring which gives me an opportunity to upgrade. As much as is live to install a set of adjustable coil overs, that's just not in the budget unless someone has a set they're ready to part with.
    Can I just put in a set of lowering springs without getting too far into it? I mean without getting into steering and a bunch of other stuff. I don't mind spending a bit on extras but...
    Let me know your suggestions.
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  2. #2 Re: Suspension Suggestions
    St. Louis
    You could do just springs. I've been lowered on Eibachs for years now.
    I will say this: If you go this route you will need engine and trans spacers to keep the axle alignment (which you can make yourself- instructions should be on here), anti-pogo washers on the fronts (they are just cradle spacer washers- look it up on here), you will eat struts faster (KYB Excel-G or GR's- whatever is cheaper) because last I checked no one makes a strut for these cars being lowered, and your ride quality will be more harsh. I DD my lowered GP and I've learned to go slow over speedbumps and watch the entrance/exit angle on steep driveways.
  3. #3 Re: Suspension Suggestions
    Canada
    Thanks for the information, FordMan. I also DD by GTP and the roads here are amongst the worst so I do plan to drive carefully. Mercifully, my commute is only 20 minutes on generally good roads.
    I've been considering AGX adjustable struts. Would I be able to increase the ride height for most of the time even with the lowering springs?
  4. #4 Re: Suspension Suggestions
    St. Louis
    Not sure on the AGX. Ride height is set by the springs, not the struts. Struts just dampen the impact of bumps.
    Here is some info on lowering a GP--> Want to lower your car? Look in here!!
  5. #5 Re: Suspension Suggestions
    Canada
    Thanks. The foolishness of my question hit me shortly after posting.
  6. #6 Re: Suspension Suggestions
    St. Louis
    No stupid questions, but you may get a smartazz response, lol... All good.
  1. tire and suspension suggestions
    By Blue GTP in forum Tires & Wheels
    Last Post: 06-27-2013, 09:10 PM
  2. Stiffened Suspension up... looking for suggestions!
    By coolone in forum Brakes/Suspension/Chassis
    Last Post: 01-11-2012, 02:02 PM
  3. Time to refresh tired suspension! Suggestions?
    By rcdino1978 in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2011, 05:46 PM
  4. suspension makeover. opinions and suggestions plz.
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 01-24-2011, 05:37 PM
  5. Suspension suggestions
    By travon802 in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 02:12 PM
