Thread: Radiator fans kicking on at 210
Results 1 to 3 of 3
  1. #1 Radiator fans kicking on at 210
    Donating User
    Jul 2014
    Minnesota
    I have an 03 GP GT and I noticed that when sitting the coolant temp will rise to around 210 and then the radiator fans kick on. I have had 3 other GPs and the temp hasn't gotten that high. When are the fans supposed to kick on? If that's normal there must be some other issue I guess
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Radiator fans kicking on at 210
    St. Louis
    212* and 226* are the temps.
    Probaby wants to see 213-214 before turning the low speed fan on.
    The temp gauge on the dash is known to be "off". If you have a scanner that can read live data you should be able to see the actual coolant temp that the PCM is reporting.
  3. #3 Re: Radiator fans kicking on at 210
    Donating User
    Jul 2014
    Minnesota
    Thank you very much, that is very helpful.
  1. Radiator Fans
    By MDCruzer in forum General Grand Prix Discussion
    Last Post: 10-16-2014, 06:42 PM
  2. Radiator fans die
    By Jtiger360 in forum General Tech Discussion
    Last Post: 04-03-2014, 03:14 PM
  3. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  4. coolings fans not kicking on , on a 2000 grand prix se 3.1 v6
    By scottwade83 in forum Introductions/Noob Questions
    Last Post: 07-15-2012, 08:48 AM
  5. Radiator Fans
    By Garry in forum General Grand Prix Discussion
    Last Post: 05-18-2012, 09:08 AM
