Thread: Strange Fuel Gauge Problem
Results 1 to 2 of 2
  1. #1 Strange Fuel Gauge Problem
    Jul 2023
    Montana
    So, I have searched through the forums and google to try and figure out this problem. No luck as yet. I just got this 05 Grand Prix (I believe it's a base or GT...not sure) with the 3.8L. When I got the car, the owner said the fuel pump was bad. I tested for pressure and yep, no pressure. The fuel gauge was reading just below 1/4 tank so I believed he was right. I ordered a new pump assembly...a complete unit with a new sender with it. When I went to pull the old pump out, I found the tank to be totally empty...with the gauge reading just below 1/4. I went ahead and installed the new pump assembly thinking ok, the sender is bad. Nope!! New sender, new pump and same problem....the gauge reads 1/4 tank off from where it should read. Any ideas on a fix for this? Thanks!
  2. #2 Re: Strange Fuel Gauge Problem
    St. Louis
    Sounds like something is not letting the float arm move properly, thus hanging up at the 1/4 mark. Is there any change the arm got bent when installing the new one?
  1. Fuel gauge problem
    By 1995brian in forum General Grand Prix Discussion
    Last Post: 01-29-2013, 05:49 PM
  2. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  3. 2000 GT Fuel Gauge problem
    By Hozer1980 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2010, 05:09 AM
  4. strange noises from the dash near gauge cluster
    By tjhgtp86 in forum General Tech Discussion
    Last Post: 02-22-2010, 11:21 AM
  5. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
