Thread: 2002 GP parking lamp assembly (driver side front)
Results 1 to 4 of 4
  1. #1 2002 GP parking lamp assembly (driver side front)
    Feb 2016
    North Carolina
    There is a small gray round "plug" thing when you look at the back of this assembly. I am sure it has to do with letting air in / out of this assembly, to prevent moisture build up inside, how does it work?
    I looked at one very closely and I can't see any kind of hole in it? I checked one that never got moisture in it and like I said, no hole??? So how does it work?
    Also, I have had issues with this assembly only on the driver side, getting moisture in it. I purchased a second new one and it too got moisture in it within two weeks.
    I had replaced them because the originals were "gone" no good anymore.
    The first new one that got moisture in it I checked for leaks but found none.
    Any ideas why two have this problem?
    the inside gets "frosted over " with moisture. New one on passenger side, same brand is OK.
    Al
  2. #2 Re: 2002 GP parking lamp assembly (driver side front)
    St. Louis
    I've always run a bead of clear silicone around the entire thing where the lens meets the housing even on "new" ones. Never had an issue after that. The only other thought I have would be that the rubber gasket around the light blub retainers isn't as tight as it should be and lets moisture into the housing.
  3. #3 Re: 2002 GP parking lamp assembly (driver side front)
    Feb 2016
    North Carolina
    Thanks for the comment on the gasket FordMan 77.
    I took the entire unit out again and checked it, it looked OK and when I put it back in, it no longer gets moisture in it. I think it is the gasket around the socket. By pulling it out and installing it again I think the gasket sealed better. The gaskets look OK.
    Can those gaskets only be replaced, or do you have to replace entire socket assembly?
    Al
  4. #4 Re: 2002 GP parking lamp assembly (driver side front)
    St. Louis
    You can likely find a suitable replacement in a parts store. Just take the old one with you and match it up.
  1. 2002 Pontiac GP headlight assembly,passenger side.
    By alok in forum General Grand Prix Discussion
    Last Post: 03-16-2017, 05:23 PM
  2. Replacing 2002 Grand Prix SE front driver side plastic fender liner
    By SwindonLandfill in forum General Grand Prix Discussion
    Last Post: 09-24-2016, 07:23 PM
  3. WTB driver's side tail light assembly and autodim rearview mirror
    By buickman104 in forum Wanted To Buy - Parts
    Last Post: 05-05-2014, 10:23 PM
  4. driver side parking and fog lights not working
    By shelbyguy04 in forum General Tech Discussion
    Last Post: 03-31-2013, 12:30 AM
  5. WTB: Black 04+ driver side power mirror assembly.
    By Koniig in forum Wanted To Buy - Parts
    Last Post: 03-19-2013, 01:06 PM
