Thread: Which motor and trans mounts do I go with?
Results 1 to 20 of 21
  1. #1 Which motor and trans mounts do I go with?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    So I looked at my trans mount today and it looks pretty dry rotted and cracked so I'm wanting to replace it now the question, are poly mounts really any better than OEM ones and I'm planning on lowering with in the next few months but don't have the $ for the spring and everything right now would it be OK to install the spacers on the mounts with the stock springs?
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Which motor and trans mounts do I go with?
    GTP Level Member
    springfield IL
    i got some from rock auto, they were the mid priced ones. filled with fluid. zero shaking at idle also.
  3. #3 Re: Which motor and trans mounts do I go with?
    Jul 2010
    Coquitlam,BC,Canada
    I used these.....
    3.5 years later, all is good.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Which motor and trans mounts do I go with?
    I would get solid rubber replacement lower mounts.
    Poly upper squares/bushings.
    If you want literally NO movement, then go with poly lowers.
    I had them, and they'll shake your teeth loose...but worth it from the performance aspect of things.
  5. #5 Re: Which motor and trans mounts do I go with?
    Oct 2015
    Ya but how much "performance" is actually gained is it worth it?
  6. #6 Re: Which motor and trans mounts do I go with?
    Enfield, CT
    Gonna be installing this one today.
    DEA A2818HD Transmission Mount
    http://www.amazon.com/DEA-Products-A...ds=trans+mount
  7. #7 Re: Which motor and trans mounts do I go with?
    Quote Originally Posted by HighOctaneRacing View Post
    this is what my regal came with. i changed mine to the gtp tranny mount. it looks like a smaller engine mount.
  8. #8 Re: Which motor and trans mounts do I go with?
    Enfield, CT
    Quote Originally Posted by ScottyDoggs View Post
    There really isn't a "GTP" tranny mount but anyways why the hell would you switch to that crappy mount?
  9. #9 Re: Which motor and trans mounts do I go with?
    when that one goes bad you'll see why i changed it to the other style. theres nothing so great about it. and if you search for a regal trans mount at any parts store web site, that mount comes up.
  10. #10 Re: Which motor and trans mounts do I go with?
    Jan 2021
    Ohio
    Do you know if that will fit my 2001 Grand Prix SE, with a 3,1 motor?
  11. #11 Re: Which motor and trans mounts do I go with?
    Oct 2015
    High octane my trans mount doesn't look like that it looks more like the motor mount are they the same?
  12. #12 Re: Which motor and trans mounts do I go with?
    Enfield, CT
    There are 2 styles of trans mounts. I chose the newer one. Much better design.
    Sent from my LG G3
  13. #13 Re: Which motor and trans mounts do I go with?
    Oct 2015
    So the one you picked out is the same fittment and will fit my 99 gp its just an updated style?
  14. #14 Re: Which motor and trans mounts do I go with?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    yes it will fit..installed the same one in my 2000 gtp
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  15. #15 Re: Which motor and trans mounts do I go with?
    Oct 2015
    OK thank you guys I'll probably just get that one than
  16. #16 Re: Which motor and trans mounts do I go with?
    Oct 2015
    So now that I know the Mount stuff does anyone know if installing the mount spacers for lowering would be bad without the springs in yet. If there's no bad effects I'd probably change the mount and install the spacers in a few days and then about two weeks after that when I get paid install canuck motorsports lowering springs
  17. #17 Re: Which motor and trans mounts do I go with?
    the spacers are to keep your axles level. so if installed now the geometry would be off till its lowered. id just do the mounts and spacers when you do the springs. they dont take much time to swap out really.
  18. #18 Re: Which motor and trans mounts do I go with?
    Just get a solid rubber, non-fluid filled one.
    It doesn't really matter. You're over thinking it. It's a mount.
    Unless you go poly, they all really still flex. There is no "performance" gain, other than no movement under load along with better power transfer when you stab into it.
  19. #19 Re: Which motor and trans mounts do I go with?
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    I went all polys and I don't think the vibrations are that bad. Guess it all comes down to individual opinion. my motor doesn't move AT ALL now though
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  20. #20 Re: Which motor and trans mounts do I go with?
    Jan 2021
    Ohio
    Quote Originally Posted by mrbreezeet1 View Post
    Amazon.com
  1. Replies: 30
    Last Post: 11-21-2014, 11:28 PM
  2. Question about filling motor/trans mounts.
    By nik12937 in forum General Tech Discussion
    Last Post: 04-06-2014, 07:42 AM
  3. WTB ZZP Billet/Polished Dog Bones, Poly Motor, Trans Mounts
    By GrandPrix06GT in forum Wanted To Buy - Parts
    Last Post: 03-19-2014, 08:43 PM
  4. Bad halfshaft or bad motor and trans mounts?
    By GRAND98 in forum General Tech Discussion
    Last Post: 08-18-2012, 05:27 PM
