Thread: Looking for trans swap advice
Results 1 to 3 of 3
  1. #1 Looking for trans swap advice
    Nov 2021
    Reading, PA
    So the trans is doing all sorts of weird torque converter stuff. Time to put in the one from the donor car. I haven't done a trans swap since '02. Anybody have any advice to make it easier for me, other than general stuff? I've got Jack stands and a cherry picker...
  2. #2 Re: Looking for trans swap advice
    St. Louis
    A long extension to get to the backwards bolt on the trans bracket. A Trans-go shift kit would be good insurance to help the replacement live longer since you'll have the pan off to change the fluid/filter anyways. If you really want to get into it install an updated 4th clutch hub so you lower the risk of loosing overdrive from stripped splines.
    Since the trans will be out personally I would check the bolts on the rear cover of the engine since they often are only finger tight and can cause leaks that can only be addressed by pulling the trans. Cheap insurance. There is info on here regarding that issue.
    If your engine and trans mounts are old/questionable now would be the perfect time to replace those as well.
    While the trans is out check where all the steel brake and fuel lines come up the drivers side of the firewall. I always remove the insulation from around the lines so they don't sit against water soaked insulation and rot out 'cause they're a b*tch to get to once the drivetrain is back in place. Been there, done that, lol...
  3. #3 Re: Looking for trans swap advice
    Nov 2011
    NY
    Make sure you have that piece (forget it's name) that is used with engine hoist that lets you angle the engine/trans while lifting or dropping from the bay. It's a Time saver considering it's all a matter of inches and tight fit!
    I have pics using and not using it but would have to dig them up...
    While the engine and trans is apart, might as well do the rear seal & cover gaskets lol.
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. '04 Trans Swap - What parts should I replace on donor trans before installation?
    By zookman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2016, 06:50 PM
  3. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  4. Need trans help/advice
    By Jackblack99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2012, 05:43 PM
  5. need advice about trans coolers.
    By kirkkarem1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2010, 04:40 PM
