Thread: LED headlights
Results 1 to 9 of 9
  1. #1 LED headlights
    Jun 2018
    Lehigh Valley
    Looking to upgrade the headlights on my 97 as the light output is abysmal at best on a sunny day. This website has bulb kits to upgrade to LED's. Are any of these good and is it worthwhile? If not what other options are out there? I want something I can just plug in and go whether it's a complete headlight assembly or the bulbs. I tried to contact classy retro fit and never received a response.
    https://www.theretrofitsource.com/bu...iac+Grand_Prix
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: LED headlights
    Dec 2008
    Lawndale, CA
    Try contacting them through their Facebook page. That’s how I’ve contacted them.
  3. #3 Re: LED headlights
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I have a set of ZZP LED fogs if you're interested. I used them along with ZZP main LEDs which were pretty bright. They were plug and play.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: LED headlights
    Sep 2021
    Canada
    PS: All 4 LEDs were plug and play, the HIDs needed ballasts of course, that are now secured to the upper rail near the radiator.
  5. #5 Re: LED headlights
    Sep 2021
    Canada
    I used Sylvania HIgh Output LEDs on the high beams and HIDs on the low beams, the length of the bulb was too long for the HID to fit in the space for the low beam. No issue with Sylvanias in the lower driving lights. Those by the way, make a huge difference to seeing curbs etc in wet weather.
  6. #6 Re: LED headlights
    Mar 2018
    NY
    Stock lighting on these cars suck, even right down to the dome lights. My GP I am still with HIDs, but my '15 Explorer I am using Seabright LEDs which I purchased off Amazon after doing some research & from some recommendations on the Explorer board. It was a huge improvement over the factory halogens which were terrible. I do wish they were slightly brighter still, but thats just the limitations of the factory housings. So far so good December will be a year with them.
  7. #7 Re: LED headlights
    Sep 2014
    Worcester, MA
    I'd consider replacing they headlight housing. If you can't see well with the standard / basic Sylvania bulbs (not the Ultras) then you probably have totally worn out & yellowed lenses. Your light is probably being diffused / scattered all over the place.
    The factory headlights are actually totally fine & sufficient, as long as they are in good condition.
    -Bob C.
  8. #8 Re: LED headlights
    Jun 2018
    Lehigh Valley
    Thank you for all the suggestions. I'll be sure to update with what direction I'm taking and if I have any other questions. This is the car my daughter drives and I want to make sure she can see better since she will be driving much more at night this winter.
  9. #9 Re: LED headlights
    Mar 2018
    NY
    My '15 Explorer I am using Sealights LED bulbs in my headlights. Purchased them off Amazon after some recommendations on the Explorer board. They are 200x better than the stock halogen lights and am happy with them even nearly a year later, however I still wish they were slightly brighter. At that point your just stuck with the limitations of the housings. Factory it uses 9005 halogen bulbs & a shutter to switch from low beam to high beam. As the '04+ GP guys here know 9005 is the bulb for the highs so that just show how crappy the housings are in these explorers. Meanwhile I am happy with the light output of the stock halogen projectors on my '12 Fusion. I think its the same thing with the Grand Prix of this generation. Your just at the mercy of the housings. I've been through a number of different setups with mine over the years. The only one I've ever been fully happy with is the TSX retrofitted projectors with 4300k hids. They light everything up nicely and evenly.
  1. 06 GXP LED headlights
    By GXDEMON in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2018, 09:08 PM
  2. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  3. Looking for headlights
    By OldFart in forum Canada
    Last Post: 02-21-2012, 10:52 AM
  4. Need new headlights
    By maddog39 in forum Visual/Body Modifications
    Last Post: 09-29-2009, 07:04 AM
