Thread: 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
Results 1 to 5 of 5
  1. #1 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
    May 2008
    Florida
    The mode control really does not work much anymore for the vent location selector. dual mode climate control.
    I am hoping it's just a bad line? If so, something I can grab in preparation of repair/replacement before I pull the dash panel off?
  2. #2 Re: 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
    sounds like the vac pump actuator broke, can be seen in this thread. Blend Door Actuator Replacement
  3. #3 Re: 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
    May 2008
    Florida
    Will check it out, much appreciated!
  4. #4 Re: 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
    FWIW, it's not vacuum actuated, it's electrical and if you open up the actuator after you change it out likely there's one gear cracked and not allowing it to work.
  5. #5 Re: 2000 GTP - HVAC Mode selector not working - slightly hear hissing behind the dash
    dont think he talking about the heat or cold, but vent, floor defrost is not working.
  1. HVAC Mode Selector , A/C Light and Blend Actuator
    By turbojimmy in forum General Tech Discussion
    Last Post: 05-04-2018, 08:07 AM
  2. 3.8L engine and transmission out of a 2000 regal. HEAR IT RUN
    By noboostnogo in forum For Sale - Parts
    Last Post: 08-25-2014, 03:09 PM
  3. weird hissing in dash...
    By 2000GTP in forum General Tech Discussion
    Last Post: 06-19-2012, 03:09 PM
  4. Dash, HVAC lights not working
    By christopher8911 in forum General Tech Discussion
    Last Post: 12-20-2010, 10:02 PM
