Thread: Won't Shift Out of Park (sometimes)... Ignition Switch?
Results 1 to 16 of 16
  1. #1 Re: Won't Shift Out of Park (sometimes)... Ignition Switch?
    SE Level Member MichEE's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by panelbeater View Post
    GT
    I am looking for the pinout diagram for the shift lock plug under the shifter for my 2002 GP SE. Any help would be appreciated.
    Did you ever get what you needed and solve the problem?
  2. #2 Re: Won't Shift Out of Park (sometimes)... Ignition Switch?
    Union City CA
    I never got the pinout so I used a test light to make sure I wasn't connecting 2 hot wires and went with my best guess for the 2 wires in question. 50% chance of getting it right the first time and I did. One thing of note. The wire keeper that snaps into the frame of the shifter seems to hold the harness in too tight of a position so that the shifting action over time probably work hardens the the wires, causing them to break. I didn't snap mine back in this time. I'll see if that helps. The only wiring diagrams I came up with were not correct for what I actually had.
  3. #3 Re: Won't Shift Out of Park (sometimes)... Ignition Switch?
    Aug 2008
    Michigan
    thanks for the info.
    Mine ended up being a rusty shift leaver. A little grease and it was OK. It was worn though and if it happens again then I'll need to replace it.
  4. #4 Re: Won't Shift Out of Park (sometimes)... Ignition Switch?
    Union City CA
    Fixing the two broken wires has fixed the problem as well as the "key won't go into off and out" position problem. I guess sometimes it's just a simple repair vs throw a new part in there. Thanks for all you folks' ideas because you stimulated me to think "a little more to the left".
  5. #5 Re: Won't Shift Out of Park (sometimes)... Ignition Switch?
    Aug 2008
    Michigan
    that's what this is for imo! Glad you got it!
  1. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  2. Ignition switch problems
    By speedracer88 in forum General Tech Discussion
    Last Post: 01-18-2009, 08:39 AM
  3. Commutator on Ignition Switch
    By catcamvegas in forum General Tech Discussion
    Last Post: 07-25-2008, 10:06 AM
  4. Ignition Switch Replacement?
    By 02BlueGT in forum General Tech Discussion
    Last Post: 04-06-2008, 08:59 PM
  5. Park Ave owners welcome?
    By gonneville in forum Introductions/Noob Questions
    Last Post: 01-11-2008, 10:13 AM
