Thread: Weird fuel issue
Results 1 to 6 of 6
  1. #1 Weird fuel issue
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    I went to a buddy's house last night, and was parked nose- in on a little bit of an incline. When I wet to leave, the car started sputtering something fierce. I pulled into a parking lot, and pulled the codes, and had a p0301 & p0201. Limped it home, cleared the codes, went in to bed. Got up this am to run one of the kids to school, and it drove as good as ever again. If the injector's going, NBD, but it strikes me odd that it only happened after parking like that the night before. the day prior I had driven 150-ish miles with no issues whatsoever. I know that at least my sending unit is going out, but fuel pressure was around 53 psi at idle, so it seems like the pump and FPR are otherwise functional. Maybe crap in the tank? That seems a little strange too, as it's always fed top-tier 93 octane. Any ideas?
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  2. #2 Re: Weird fuel issue
    Apr 2020
    Upstate SC
    Nothing? Trying to put off replacing the fuel pump a little longer if I can, if anyone else has had a similar experience rooting from some other issue.
    99 GTP:
  3. #3 Re: Weird fuel issue
    Apr 2020
    Upstate SC
    **Update- I went out on my lunch break, and the car seemed to do ok till I got back in at the store. Throwing a p0201 and p0301 again, stuttering, and watching live data, the #2 cyl is misfiring, but not the #1, and no code for cyl. # 2. What I'm seeing in real time is not matching the active code. Any ideas???
    99 GTP:
  4. #4 Re: Weird fuel issue
    St. Louis
    I'd check the wiring harness to the injector and make sure it's good. IIRC, you can put a 194 blub in the injector harness that clips to the injector itself and see if it is getting power correctly. I've had critters chew up wires back there before and it wasn't obvious for a bit until it corroded enough to cause an issue.
  5. Likes ThatOldCarSmell liked this post
  6. #5 Re: Weird fuel issue
    Apr 2020
    Upstate SC
    Quote Originally Posted by FordMan77 View Post
    I'll give that a shot this evening after work. so unhook the harness at the injector and put the bent leads from the bulb in the harness? Then key on engine off, or turn the motor over all the way?
    99 GTP:
  7. #6 Re: Weird fuel issue
    St. Louis
    Check out this post, might help you out--> P0203 and P0303 help??
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Help! Weird KR Issue
    By wa04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 11:35 PM
  3. weird car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 07-29-2010, 09:16 AM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
