Thread: Anyone installed these headers?
Results 1 to 9 of 9
  1. #1 Anyone installed these headers?
    Nov 2014
    Macon, GA
  2. #2 Re: Anyone installed these headers?
    look like speed daddy, maybe knock offs. id do it.
  3. #3 Re: Anyone installed these headers?
    Nov 2014
    Macon, GA
    Already bought a pile of stuff today, band clamps, and a couple o2 extension.
    cat to make it somewhat legit.
  4. #4 Re: Anyone installed these headers?
    May 2008
    Schuyler, NE
    They usually don't fit without some heavy persuasion or a welder. The crossover isn't bent correctly, so it's very difficult to line them up. Some sets are better than others though.
    They are also going to leak.
    Headers for the most part are worthless on these cars.
  5. #5 Re: Anyone installed these headers?
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    why would headers be worthless? I guess turbo cars are only using power logs technically. I'm curious to hear your opinion though.
  6. #6 Re: Anyone installed these headers?
    May 2008
    Schuyler, NE
    Because they don't increase power, and the cheap ones are nothing but headaches.
  7. #7 Re: Anyone installed these headers?
    headers dropped my boost psi from 7 to 5 psi, they work. lower boost means the exhaust is flowing better vs stock junk.
    turbos dont need a really need a header as your just blowing it into a turbo thats less then 2 foot from the exit of the rear manifold.
  8. #8 Re: Anyone installed these headers?
    The Boss Iceman6669's Avatar
    Jun 2011
    Headers don't increase power by themselves. They allow you to do other things to increase power.
    I ran speed daddy headers on my car back in the day, and I did have to "convince" them to fit. I got them on and they never leaked once they were on. BUT install took some doing.
    2011 F-150 Yote powered
  9. #9 Re: Anyone installed these headers?
    May 2008
    Schuyler, NE
    Headers didn't drop my boost at all. Mathematically, it makes no sense for them to drop boost, unless something was wrong with your stock system. If that's the case, absolutely boost will drop.
    It also makes no sense saying that they don't increase power, but allow you to do other things that will increase power. If they are a restriction, you will gain power from replacing them, period.
  1. Installed headers now problems
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2011, 05:29 PM
  2. installed headers need help
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 01:49 AM
  3. SD Headers installed and A+++++
    By DCVING in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 06:56 PM
  4. headers installed
    By boostedcompg in forum General Tech Discussion
    Last Post: 12-19-2009, 03:24 AM
  5. ZZP Headers installed!
    By Reptile in forum General Tech Discussion
    Last Post: 03-10-2009, 11:11 AM
