Thread: 2007 supercharged Balancer repair sleeve? Front seal replacement
Results 1 to 7 of 7
  1. #1 2007 supercharged Balancer repair sleeve? Front seal replacement
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I am getting ready to replace my front crankshaft seal and sensor on my 2007 Grand Prix supercharged series III. Does anyone know if there is a balancer repair sleeve for this model? I searched and did not find much on this. I want to have one on hand just in case there is a groove on the balancer when I get it off. Also any tips or videos on how to install the sleeve if there is one. Any help is appreciated.
    Thanks
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    see if these links work, this was for my 98 regal, see if the seal part # is the same, then it should work.
    https://hosting.photobucket.com/albu...psashf10yn.jpg
    https://hosting.photobucket.com/albu...psjo9t0y7k.jpg
  3. #3 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Doesn’t look like it is the same. I don’t see a front skf seal # for mine.
  4. #4 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    it could be any brand crank seal. if they are the same the balancer part should be the same size.
    the parts store i got that at used to be a napa, now a car quest, so they still had the " books" , where they found it, then had to order it.
  5. #5 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I looked up the harmonic balancer again on Rock Auto and decided just to get a new balancer just to be safe. It was cheap enough ($77) just to have piece of mind.
  6. #6 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    if you bought it, use it, these balancers do fail with age. mine did at 243k.
  7. #7 Re: 2007 supercharged Balancer repair sleeve? Front seal replacement
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Definitely will then. Mine has 217k
  1. Snout seal replacement.
    By Deno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2020, 09:00 AM
  2. Front seal replacement
    By alenw62 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2016, 08:10 PM
  3. Front seal replacement
    By mechanicboy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2016, 08:45 AM
  4. Front Oil Seal Leaking after replacement again..HELP
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2014, 12:24 PM
  5. New Front Crank Oil Seal Leaking - Grooved Balancer?
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 03:58 PM
