Thread: Water in passenger footwell
Results 1 to 18 of 18
  1. #1 Water in passenger footwell
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi All ,
    Its been raining non stop here the last few days. I got home today and noticed my regals windows fogged up . I checked the passenger footwheel and there carpet is soaked.
    Could be the sunroof, but i thought that drained on the driver side. Anything i should look for to see where it might be leaking?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Water in passenger footwell
    Mar 2014
    Tucson
    part number 15794785
  3. #3 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    Gm parts website claims it doesnt fit the regal
  4. #4 Re: Water in passenger footwell
    bought my cowl fix on ebay for my regal. iirc its the same part for a gtp, 8 bucks and 15 minutes of time. good time to change or add the cabin air filter.
  5. #5 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    is it this Pn 15794785? Any chance you have a link to it on ebay?
  6. #6 Re: Water in passenger footwell
    Mar 2014
    Tucson
    Oh dang. They are charging a premium for them things now. I'm seeing prices between $60 and $80.
  7. #7 Re: Water in passenger footwell
    Jan 2014
    AR
    It is possible for water to enter the interior through doors when the weather liner behind the trim panel has an area where the butyl isn't stuck to door shell. Leak questions always get that same response first though. If a paper towel stuffed between door trim panel and door sill trim panel gets wet, its the door.
    Avoid parking in uphill orientation if possible when heavy or extended rain is forecast, to minimize the cowl leak.
    If one of the four sunroof drains stops up, headliner may get wet somewhere. Compressed air blown gently up the hoses to clear, from the wheelwell ends. I haven't seen a sunroof "leak" end up in the floor.
    Just a couple tips from over a decade of 99 GP use plus GM leak training as a tech. Some of your electronics may be swimming under that carpet.
  8. #8 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    Last night i went outside and cleaned up the debris that was on the cowl. I found that the screen on the passenger side had broken. I pushed it back up and sprayed over the lower part with some flex seal . worst case ill grab a new one from the JY.
    One company appears to have the part for cheaper, i just need some confirmation on what the correct number is for the regal since GM parts lists the 15794785 as not fitting the regal .
  9. #9 Re: Water in passenger footwell
    Mar 2014
    Tucson
    While I can't personally confirm it will work on a Regal, a couple of Amazon reviews state it will work on multiple w-body models. Take that for what it's worth.
    Awesome! If you have a GM W-Body car (Chevy Impala, Pontiac Grand Prix, Buick Regal, Olds Intrigue, etc.) This is just the thing to keep rain water from soaking your cabin air filter before ending up in your heater box and all over the floor. Simple installation and fixes a bad design!
    This worked great on a 1999 Buick Regal LS. I had to modify my vent cover slightly by cutting plastic off of it so that it wouldn't press up against the new deflector cover, which was easily done by using a small saw to cut it away so that it would fit.
  10. #10 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by BrandonHall10 View Post
    Thanks, if it was just a 10 dollar part, id buy it and take the chance, but at 60 bucks, its more of a risk.
  11. #11 Re: Water in passenger footwell
    I can 100% confirm it fits a Regal. I added it.
    Cheapest way to get one, hit the yard and look at regals and gp's/montes till you find one. It's a dumb piece of plastic, guy should let you nearly have it free
  12. #12 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    Where exactly does it go under the cowl ?
  13. #13 Re: Water in passenger footwell
    Passenger side right above where the cabin filter would sit.
  14. #14 Re: Water in passenger footwell
    Water in floorboard (Take 2) - The Permanent Fix its the same exact job on a regal. the part number in the thread is what i used to search for mine.
  15. #15 Re: Water in passenger footwell
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by 04lss View Post
    Hi All ,
    This happened in my GTP. It had no sunroof. I got this answer (of course) after I killed the car.
    Get the cowl part. $80 is cheaper than a new interior carpet.
  16. #16 Re: Water in passenger footwell
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    If you go the route of looking in a junkyard, I had the best luck locating one in an impala (06+ ish). it seems all the other similar vehicles that were any older did not have the cowl piece at my local junk yards.
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  17. #17 Re: Water in passenger footwell
    Quote Originally Posted by Hurricane87 View Post
    only 80 bucks is robbery. under 10 off the internet is a win.
    last time my floor got wet i pulled it up in the pass front then put some wood sticks to hold it open to air. then left a fan blowing on it. if left wet it will stink like hell. if it does smell already, baking soda will kill the smell. just sprinkle it on the rug, use a shop vac or car was vac to clean it up later on. dont use the house vac, the b/s will kill the vacuum.
  18. #18 Re: Water in passenger footwell
    Sep 2014
    Richmond Virginia
    As soon as i found the water i drained it with a shop vac, there wasnt much in there suprisingly.
  1. Tell me if you've heard this one before: Water in passenger footwell!
    By Bugsi in forum General Grand Prix Discussion
    Last Post: 04-05-2017, 01:43 PM
  2. Water in passenger floor of car.
    By PTGsDaytona500GTP in forum Visual/Body Modifications
    Last Post: 06-27-2013, 06:06 PM
  3. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  4. rain water on passenger floor
    By talontedGTP in forum General Tech Discussion
    Last Post: 06-11-2011, 11:32 PM
  5. Passenger side water leak
    By Perry125 in forum General Tech Discussion
    Last Post: 07-08-2010, 11:46 PM
