Thread: Power steering pump noise
Results 1 to 9 of 9
  1. #1 Power steering pump noise
    Banned - Busted For Scamming
    Feb 2009
    Ok, so i have replaced the power steering pump 3 times now, rebuilt unit from autozone, each time i have properly bled the system turning left to right, etc. Its full on fluid each pump and it makes noise constantly, and whines more under acceleration when wheel is turned. My question is has anyone had this problem, and could it be something with the rack and pinion causing the pump to make noise? The rack is not leaking, and i dont know what is the matter with the pumps i am getting, do you think that its just a crappy rebuilt unit and i should complain and get my money back? Any input appriciated. Thanks.
  2. #2 Re: Power steering pump noise
    TDCRacing
    Guest
    Maybe try a different manafacturer. I mean is the noise real loud or what?
  3. #3 Re: Power steering pump noise
    I live here. UR LOSN's Avatar
    Rockford, IL
    MAKE SURE!!! that the power steering lines are NOT touching anything!!!!!! even a little rub will make the system ungodly loud.
  4. #4 Re: Power steering pump noise
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    I had the same problem with rebuilt pumps. A bad rack can cause the pump to fail, but I don't think it will make noise right away. Turn the wheel from side to side, and see if you can feel the rack binding or sticking. I took mine to the dealership, and they checked out the rack for free.
    If the rack is fine, new pumps from GM are $172 (I've seen them cheaper online). For the record, I got charged $200 for a reman pump (dumb, but I learned my lesson).
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  5. #5 Re: Power steering pump noise
    Feb 2009
    yea it makes a constant dull whine, not really high pitched, but when you turn the wheel left or right under acc. it makes a higher pitched whine. I think im gonna call autozone and tell them to switch me to a different manufacturer or give me a refund. It makes my car sound like a p.o.s. and i dont have the money for a gm pump. Thanks for your help everyone.
  6. #6 Re: Power steering pump noise
    baltimore, md
    I am having the same problem right now with my '01 GT. I don't know much about cars, but I don't think the pump has a problem. Along with this whining noise the abs light and traction control off lights are also on. I replaced the R front hub and it is still the speed sensor. not sure where to go from here.
  7. #7 Re: Power steering pump noise
    Chicago
    Quote Originally Posted by goody8545 View Post
    I was told by a dealer that there was a cover panel on the underside of the car that can fall off and expose the traction control and abs circuit causing a fault. I never confirmed this. I have the same issue now with the dummy lights for tcs and abs. Last time it happened I swapped out the left front hub and hope I don't have to go for the right. I noticed, however, that the wiring and harness on the hubs are delicate and its easy to bang them up with all that steel around. I nearly hit one with a torch while replacing a rotor. You may even just need to pop the harness back on if it came loose.
  8. #8 Re: Power steering pump noise
    Feb 2009
    found out my noise was a combo of the power steering pump and the a/c clutch bearings which i have yet to fix.
  9. #9 Re: Power steering pump noise
    Chicago
    Same problem on and off through the years and it's worse after a little slalom. I always just added fluid. A/C clutch is starting to make noise now too.
  1. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  2. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  3. 2005 Power Steering Pump Seems Thrashed
    By Myoldmopar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2009, 07:28 PM
  4. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
  5. belt help, bypassing power steering pump
    By skates in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2008, 11:24 AM
