Thread: Code Scanner
Results 1 to 17 of 17
  1. #1 Code Scanner
    May 2012
    Canada , Sarnia
    I am looking at getting a code scanner that can read abs and here are my two choices what would be the better scanner??
    Robot Check
    Robot Check
  2. #2 Re: Code Scanner
    ChevroSys Scan Free - Apps on Google Play
    if you own a elm327 or the likes, this is free with a droid device. ive got it, works damn good for free. reads all codes pretty much, plus live data. can even go in and clear codes in abs history, then drive and wait for the light to come back on, re scan, the new code is the issue.
  3. #3 Re: Code Scanner
    May 2012
    Canada , Sarnia
    I don't own the elm327 but is this what your talking about and this can read abs codes? because I need one to read the abs codes on my gxp
    https://www.amazon.ca/ELM327-Bluetoo.../dp/B00E3VDL80
  4. #4 Re: Code Scanner
    thats the deal. but the mini's tend to be hit or miss. theres a longer one that tends to work better.
    then theres another brand bafx? iirc. its like 20 and will work. BAFX Products - Bluetooth OBD2 OBDII Car Diagnostic Code Reader Scanner Tool | eBay
    yes it reads abs codes, p, c, and u codes.
  5. #5 Re: Code Scanner
    May 2012
    Canada , Sarnia
    Got my scanner and got scanned the abs codes and this is what came up could it be just a break in the left front wheel speed harness ?? causing all the lights to come up on the dash
    Codes
    C0035 - Left front wheel speed sensor - current
    C0896 - Electronic suspension control - history
  6. #6 Re: Code Scanner
    damaged wire, or the hub is bad. sensor is built in the hub. if bad they tend to have some play. jack car up push and pull at 12 and 6 feeling for play.
  7. #7 Re: Code Scanner
    May 2012
    Canada , Sarnia
    Found the broken wire fixed it and the wheel has no play in it but the lights are still up on the dash so could the hub be the problem
  8. #8 Re: Code Scanner
    May 2012
    Canada , Sarnia
    forgot to add the C0035 code is not showing up current anymore just in the history for the abs but i cant clear it
    HISTORY CODES
    C0898
    C0896
    C0035
  9. #9 Re: Code Scanner
    if using the app i posted, you can clear history. then drive the car if the abs light comes back on, re scan. that new code will be the relevant issue.
    most of the time if the issue has been fixed, the abs lights will go out on their own.
  10. #10 Re: Code Scanner
    May 2012
    Canada , Sarnia
    I am using the app you posted when I try to clear the codes they wont they keep coming back
  11. #11 Re: Code Scanner
    Quote Originally Posted by gordster1122 View Post
    ok, you have active codes then, google them and see what its for.
  12. #12 Re: Code Scanner
    May 2012
    Canada , Sarnia
    This is what comes up on the scanner and cant clear them
  13. #13 Re: Code Scanner
    May 2020
    Pittsburgh
    If you can't clear them, it most likely means they're current. ABS. codes usually "clear" when you shut the car off. The codes are still there, but typically the light will go out unless it's actively seeing an issue.
    C0035 indicates an issue with the speed sensor. That's generally pretty straight-forward. Either the sensor is bad, cannot read the hub, or cannot communicate with the module. Check wires and connectors. If all is good there, suspect the hub.
    C0896/8 are voltage/power supply codes for the module. I'd start by finding a wiring diagram and check the wires with a meter. You're looking for the 12v power supply, and the - Ground circuit.
  14. #14 Re: Code Scanner
    you try hitting the trash can top right? been a while since ive used my app. but i know i cleared my regal and the tahoe.
  15. #15 Re: Code Scanner
    May 2012
    Canada , Sarnia
    Yeah I am
  16. #16 Re: Code Scanner
    May 2012
    Canada , Sarnia
    so today I put new hubs on and scanned nothing showing up in the abs like before but the dash lights are still showing ???
  17. #17 Re: Code Scanner
    lord you got gremlins.
    drive it a few days and rescan it, maybe something will show up.
    you can also nail the brakes in some gravel or dirt to see if the abs is working or not.
  1. What code scanner would be the best.
    By DayHeyZeus in forum Chevrolet Impala
    Last Post: 04-26-2015, 10:03 PM
  2. anyone in western mass with a legit code scanner?
    By HighOctaneRacing in forum Introductions/Noob Questions
    Last Post: 03-21-2014, 08:50 PM
  3. What Diagnostic Code Scanner do you recommend ?
    By p coico in forum General Tech Discussion
    Last Post: 12-11-2012, 03:56 PM
  4. Any low cost scanner to read 2006 Grand Prix ABS code?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2012, 09:02 PM
  5. Best OBD II Code Scanner for PC and Best Handheld Under $150
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-16-2010, 08:39 PM
