Thread: Blowing oil smoke and gas on passenger side above header. Please help disgnose.
Results 1 to 20 of 49
  1. #1 Re: Blowing oil smoke and gas on passenger side above header. Please help disgnose.
    St. Louis
    Post the exact codes it spit out on the scanner. There are a lot of different misfire codes.
    Try soaking the O2 sensor with PB Blaster or some other good penetrating oil where it meets the manifold. A torch also comes in handy on this as you can heat the manifold bung around the O2 and while it's warm try backing it out. May have to loosen/tighten a few times to get it to move. I've used a pipe wrench to back out a stubborn sensor that rounded off.
    You have to get that sensor installed or it's never going to run right.
  2. #2 Re: Blowing oil smoke and gas on passenger side above header. Please help disgnose.
    Quote Originally Posted by FordMan77 View Post
    everything he said. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^
  3. #3 Re: Blowing oil smoke and gas on passenger side above header. Please help disgnose.
    SE Level Member Wakingcrow's Avatar
    Mar 2017
    Florida
    I tried pretty much all of that and it's not coming out. The nut is stripped now so it's not going to be possible even if I take off the header again. What I need is to just hook up an o2 sensor simulator or dummy that actually works, to the wiring harness, if anyone has any recommendations. I should have a few bucks to buy or construct one tomorrow. Thanks.
    BTW P0301 cylinder misfire and I think P480 was the O2 sensor.
  1. Air Conditioner not blowing cold air through passenger side?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 04-14-2014, 07:16 PM
  2. Replies: 3
    Last Post: 04-11-2014, 08:05 PM
  3. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
  4. Blowing smoke with supercharger
    By tboy160 in forum General Tech Discussion
    Last Post: 03-26-2012, 10:57 PM
  5. Heater not blowing hot air on passenger side
    By grausj1 in forum General Tech Discussion
    Last Post: 10-31-2011, 08:15 PM
