Quote Originally Posted by Wakingcrow View Post
No the alt hasn't been removed in a couple of years after I did water pump and elbows on that side. If it's just a broken valve cover I'll be relieved but also feel like a complete idiot for all the work I put in on the header gasket without even putting in a new header. If I haven't removed it recently could it still be the problem?
if you did elbows you took the alt and bracket off. if you busted the cover you'll see it asap. just look down at the end where the alt bracket is 1/2 inch away from it.
or the valve cover gasket is leaking really bad. if you take a clean rag and drag it under the bottom of the lip and it comes up coated in oil. thats the gasket leaking.
