Thread: Coolant Temperature Sensor
Results 1 to 10 of 10
  1. #1 Coolant Temperature Sensor
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    So, the temperature gauge bottoms out, and the DIC says "A/C off due to emgine temteratures," or some such. Having been though this with the Monte, where I broke the connector in the process of changing the #1 spark plug, I deduced it was the coolant temperature sensor, and replaced it. Start the car, still no temperature reading, same DIC message.
    Did I get a defective sensor, or could something else be wrong? The current connector seems just fine.
  2. #2 Re: Coolant Temperature Sensor
    does it say ambient temp maybe? if you got auto climate control and it shows out side temps, is it showing -32? if so the ambient temp sensor went bad. its up by the rad on the rad support.
  3. #3 Re: Coolant Temperature Sensor
    SE Level Member GTP Mark's Avatar
    Dec 2019
    Canada
    Is it a aftermarket coolant temp sensor? When I had my 98 GTP I changed the sensor with a aftermarket one and it never read correctly. Swapped it out for a AC Delco one same day and it was good again. I believe the wire harness for it is just a short piece that can be unplugged at both ends and removed from the car. Take it off and remove the old factory wire loom/tape and check it out if you haven't already.
  4. #4 Re: Coolant Temperature Sensor
    Jul 2016
    Brevard County, FL
    It wasn't the ambient temperature sensor; that wouldn't cause the gauge to bottom out. The coolant sensor magically started working after four key cycles. Who's the genius who designed THAT system?
  5. #5 Re: Coolant Temperature Sensor
    new temp sensors are known to be junk, so either its bad already, or its little harness there is cooked up.
  6. #6 Re: Coolant Temperature Sensor
    Or it was a bad connection and you got lucky that it moved the right way. It's worth looking at...
  7. #7 Re: Coolant Temperature Sensor
    Jul 2016
    Brevard County, FL
    If they're all junk, why does anyone replace them? I mean, I live in Florida and I'm married, so I have no choice, but why does anyone else?
  8. #8 Re: Coolant Temperature Sensor
    ive seen ppl here replace 2 in a row that were new and dead in the box. and you need that sensor, it controls the cooling fans and sends info to the dash temp gauge. its a two part sensor, one side to the pcm, other to the dash. why the dash will still read but fans quit, or vs versa.
  9. #9 Re: Coolant Temperature Sensor
    May 2019
    Western PA
    So there are two signals produced within the sensor itself instead of being split off ? That could make it more tricky to troubleshoot should there be a problem. I recently suspected my CTS, but after troubleshooting, it seems to be OK. I don't have a heating problem, the dash temps appear normal, and the fans kick on at about the 3/4 mark on the dash. One thing that I can't explain is that when I disconnected the CTS, the fans immediately turned on. I read elsewhere on this forum that if the fans start after the CTS is disconnected, that indicates a bad CTS. Mine does that, but the cooling fans seem to be functioning normally.
  10. #10 Re: Coolant Temperature Sensor
    they default to on when unplugged, dont matter if the sensor is good or not.
  1. 02 coolant temperature sensor
    By RedBear70 in forum Introductions/Noob Questions
    Last Post: 04-20-2017, 05:31 PM
  2. Changing the coolant temperature sensor
    By Jeremy05GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2017, 10:39 AM
  3. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  4. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  5. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
