I topped off the coolant the other morning as it was a little under the cold line. Made no difference. Good to know about unplugging the sensor. Will that knock out my gauge too or does that read off a separate sensor?
I did not see any breaks in the wiring or exposed wiring that would cause a short. Between the temp sensor or to the fan. The loom going to the temp sensor is cracked and brittle but the wires still appear good.
I experimented earlier with the relays. With it running and ac on both fans were working this morning. Relay #10 I unplugged and it shut down both fans. I plugged it back in and both fans kicked on again. I then did the same with relay #12 and it shut down the passenger side fan only, however when I plugged it back in the passenger fan still stayed off. I didn’t do relay #9. I’m thinking #12 May be my issue. For $6 I think I can take a chance on it as I don’t have a working volt meter with me
