you hear the click from the dash? or under the hood? under the hood is power or ground. in the dash is a bad starter. you try hitting the body of the starter with a hammer a few times while the key is held to crank?
04 up cars have a crappy ground at the battery from what i understand. id clean and make sure thats all tight, if you see bare wire at the end of the cable the cable could be bad too.
main battery ground goes to the bell housing bolt. theres at least one other eyelet on it, two black wires to one loop, those wires tend to break off their eyelet. i have headers these days so i can see the nut that holds the grounds to the tranny, with stock manifolds iirc you can still feel it by reaching under the manifold with a 3 inch extension and a deep socket. pretty sure its a 13 mm nut. i just hade my engine out a few weeks ago.
