So you can buy a multifunction switch with a LED turn signal flasher built into it?
Sent from my SM-N920V using Tapatalk
Not to my knowledge, but from what I've seen with some newer cars, the multifunction switch with the flasher built in or localized to the hazard flash is usually compatible with LEDs. Mine is actually malfunctioning in another way as well, so I'm hoping this solves the issue.
Sent from my LM-G710VM using Tapatalk
