Thread: put it back together, now wont run
Results 1 to 3 of 3
  1. #1 put it back together, now wont run
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    i put everything back together, and when i turn the car on, it just revs to the limiter, and dies.... if you try to give it gas it just sticks at the rev limiter... and stays there, even with a little throttle. what is wrong? also the "trac off" light is illuminated, and wont go off..
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  2. #2 Re: put it back together, now wont run
    Feb 2008
    ahh, probably should have continued on your original thread on this issue. New readers don't know what you did if all they do is read this thread
    Thread reference: ----> http://www.grandprixforums.net/f81/h...ake-11142.html
    Check to see if the TB is operating correctly. Also, make sure you put the throttle cable on correctly if you took them off.
  3. #3 Re: put it back together, now wont run
    Dec 2008
    Freeman, SD.
    i found it... er "The Car Guy" did (name of the local garage) i had a tie down for a wiring harness caught in between the upper and lower manifolds, and it cracked it.... $15 to replace from the junk yard... fixing it Wednesday... but thanks..
  1. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
  2. Car wont turn off !?!
    By Billyboi6 in forum Northeast
    Last Post: 11-11-2008, 12:54 PM
  3. need help GP wont run
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-29-2008, 06:23 AM
  4. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
