Thread: Time for another swap?
Results 1 to 16 of 16
  1. #1 Time for another swap?
    Apr 2011
    North Los Angeles
    So I'm cruising around 75mph and notice the check engine light is flashing, I feel a slight vibration when accelerating. I pulled over and ran the OBD, I got the misfire 300 code. Very rough idle but decided to go on then boom, a super loud knocking sound that increases with acceleration.
    I swapped out my engine once before about 3 years ago with some help from you fine gents. Is my engine gone? Could something else cause a misfire and that dreadful sound? This website has changed a bit since then, I hope all the informative threads carried over here.
  2. #2 Re: Time for another swap?
    HUDSON
    Check to see if the flexplate is cracked first.
  3. #3 Re: Time for another swap?
    post a vid if you can. idle, then hold it at 3000 rpm and then just drop the throttle drop.
  4. #4 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    Wouldn't I need to remove the engine to check the plate?
    Here's a vid, rev to 3000 then let go
    3.8 knocking - YouTube
  5. #5 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    Also gives off the smell of gasoline.
  6. #6 Re: Time for another swap?
    Jesus that is one huge exhaust leak.
    Sounds like the rear manifold broke somewhere or at the downpipe connection.
  7. #7 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    Sounds like good news, hope you're right
  8. #8 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    Going under later, any places to check besides the obvious?
  9. #9 Re: Time for another swap?
    If that's an exhaust leak it should be very obvious and have a lot of carbon around the leak.
    I'm not so sure it's a leak, but start there since that's as good as anywhere else.
  10. #10 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    Thought it sounded like an engine knock plus the misfire code, didn't get a chance to check yesterday will do today
  11. #11 Re: Time for another swap?
    or it could be a busted rocker arm or bent or broken push rod and that sound is the valve not opening. hoping for the exhaust leak.
  12. #12 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    I looked under, around the catalytic and could feel a strong airflow in my face coming from manifold/down pipe area but couldn't locate a crack or where it was coming from, it even tore up that fabric material (heat shield insulation?) around the down pipe area. It's raining hard so couldn't get a great look but it's def coming from behind the lower engine area, crossing my fingers for anything but a busted engine.
  13. #13 Re: Time for another swap?
    Apr 2011
    North Los Angeles
    One of the spark plugs had popped off somehow, screwed it back in and back to normal, thanks guys.
  14. #14 Re: Time for another swap?
    Kemmerer, Wyoming
    Quote Originally Posted by steelholder View Post
    that's crazy, i'm wondering how that would happen
  15. #15 Re: Time for another swap?
    damn i knew that was a odd sound lol
  16. #16 Re: Time for another swap?
    Bill, doubting me are you??
    Hmmmmmmmmmmmmm.
    Exhaust leak, spark plug blown out = same thing right?
    I was damn close to real problem.
  1. Aftermarket Stereo Install? (First Time Grand Prix Owner/ First Time Forum User)
    By Kickflip Supreme in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2015, 08:58 PM
  2. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  3. swap time
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 08:14 PM
  4. Good time to swap out brakes?
    By gwizlo in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2009, 10:58 AM
  5. Swap time soon...do I have everything?
    By BwolfGT in forum General Tech Discussion
    Last Post: 08-14-2009, 01:19 PM
