Thread: Vent Controls
Results 1 to 4 of 4
  1. #1 Vent Controls
    Oct 2018
    OH
    I just purchased a 2001 Grand Prix GT. The vent control knob seems to have no effect on where the air blows out. It seems to be coming out all ports. I can feel the A/C on both the floor and the dash vents. Should I suspect the knob controller or the actuator it operates?
    Also, moving the temp control to heat seems to stop all air flow, although it does switch to heat.
    I've yet to change the cabin air filter but will be ASAP.
  2. #2 Re: Vent Controls
    Oct 2018
    OH
    Anyone?
  3. #3 Re: Vent Controls
    back side, ( firewall side) of the intake manifold is a vac line that leads to the firewall, it then runs across the firewall then down the pass fender top down to the battery area, some have a T some dont, but at that point it will run into the wire harness leading into the cab.
    check that line for a break. it often gets busted by the battery when its changed. it powers the air flow direction.
    if that line all checks out. theres a box under the dash that line runs to, that box can fail.
    or worst case is the plastic linkage on the hvac unit in the dash broke. thats no fun to fix at all.
  4. #4 Re: Vent Controls
    Oct 2018
    OH
    Thank you
  1. Bad evap vent
    By tigers40 in forum General Grand Prix Discussion
    Last Post: 07-16-2012, 06:44 PM
  2. Need to vent
    By zildjian102 in forum The Rant Forum
    Last Post: 08-13-2010, 11:20 AM
  3. down the vent
    By echarleswhyte in forum General Tech Discussion
    Last Post: 09-21-2009, 06:46 PM
  4. just need to vent here, any 2 cents is welcome!!
    By fabz77gp in forum Off Topic Discussion
    Last Post: 07-22-2008, 01:35 PM
  5. i have the need to vent
    By stlmo_gtp in forum The Rant Forum
    Last Post: 04-09-2008, 10:03 AM
