My a/c doesnt work yet again, i used a kit that came with a new compressor, condesnor, orifice tube filter and most all of the metal a/c line(all the lines in engine bay. Theres no signs of a leak or dye, pressure seems where it should be. The compressor will not kick on though. The pcm is tuned to allow a/c on even when its -0° so i know its not a temp sensor. I was thinking either the high side pressure switch or possibly the digital hvac controller itself. I know you can usually jump the pressure switch pins but mine is 3pin and i cant find which to jump. Is it possible to test the hvac controller? It appears to work and function though so i have no clue.
Sent from my LG-D851 using Tapatalk
