It was broken 6 inches from the hub plug. Not the wires from the hub to the plug. The hub wiring was ok. Fairly simple repair. Unplug from the hub, open the clips that hold it to the A-arm and then pull back the plastic wrap around the wires. I used a meter to probe the wires until I found where the break was. You can't see the break, it's broken inside the insulation.
