Glad it worked out, I wiped out the old grease and put a light coat of new white lithium grease on the copper tracks when I did mine. If after you fix the voltage issue, the check gauges light stays on that is very common with these particular years. The circuit board on the cluster itself is the culprit. Rock auto carries the turn signal switches with radio controls.
