Thread: DP Removal
Results 1 to 9 of 9
  1. #1 DP Removal
    Donating User
    Jul 2014
    Minnesota
    Hello all, just wondering what people have found to be the easiest way to remove the stock DP, primarily the front bolts. It's just something I haven't ever done before.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: DP Removal
    Long extension from under the car with an impact. Using a breaker bar can be done but pretty tight under there if the car is not on a lift.
    Heating the bolts up is helpful too if they've never been off before.
  3. #3 Re: DP Removal
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    I sprayed the crap out of the bots/nuts with PB Blaster the day before I tried removing my stock downpipe, let the car warm up for a bit, drove it onto ramps, then got under it. I used the socket (can't remember which size, maybe 13 mm), a swivel, a long extension, my breaker bar, and a can of spinach.
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  4. #4 Re: DP Removal
    The nuts should be either 13mm or 15mm. Most find the downpipe to intermediate pipe connection to be tougher
  5. #5 Re: DP Removal
    Donating User
    Jul 2014
    Minnesota
    Cool, thanks much
  6. #6 Re: DP Removal
    Oct 2017
    Las Vegas
    I found it easiest to cut the stock pipe with a sawzall just before the cat. then the bolts are easy enough to get to with anything. used a diamond blade and it cut like butter.
  7. #7 Re: DP Removal
    Donating User
    Jul 2014
    Minnesota
    I am most concerned with the front bolts
  8. #8 Re: DP Removal
    Like the great BillBoost once said, the rear bolts are the fighters, fronts are easy because they dont get rusty due to the temps they see their whole life.
  9. #9 Re: DP Removal
    Donating User
    Jul 2014
    Minnesota
    Ok that makes sense but the rear bolts are rusted into the flange pretty bad that's why I am replacing the resonator as well so I'm just gonna cut that section out and weld in a new flange and glass pack
  1. EGR removal
    By Nate25tenn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2014, 10:39 PM
  2. air box removal.....
    By daehler311 in forum Introductions/Noob Questions
    Last Post: 09-12-2014, 03:10 AM
  3. s/c removal help
    By Matt Palm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2012, 11:47 AM
  4. Oil pan Removal
    By TPStatic in forum General Tech Discussion
    Last Post: 01-03-2012, 03:53 PM
  5. TB removal
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 12:19 PM
