Thread: Stock exhaust question
Results 1 to 12 of 12
  1. #1 Stock exhaust question
    Donating User
    Jul 2014
    Minnesota
    I am looking to install my ZZP catless downpipe and I was planning to delete the resonator at the same time but I was wondering how raspy it will get with no cat and no resonator with stock muffs?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Stock exhaust question
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Very.
    GPONA #1 Cyber Bully
  3. #3 Re: Stock exhaust question
    its called drone, it will make your ears bleed, unless your a youngster, then you might like it for a while lol
  4. #4 Re: Stock exhaust question
    Donating User
    Jul 2014
    Minnesota
    So in other words don't do it
  5. #5 Re: Stock exhaust question
    Donating User
    Jul 2014
    Minnesota
    I only ask because the flange that bolts the DP to the resonator is rusted together and looks like it would not be reusable so there would have to be some cutting and a welding of a new flange
  6. #6 Re: Stock exhaust question
    you can get a glass pack and have the shop weld a new flange on the end and then use that if the res is that far gone.
  7. #7 Re: Stock exhaust question
    Donating User
    Jul 2014
    Minnesota
    Well the resonator is fine its just the flange that's all rusted to sh*t, would a glass pack change the sound much?
  8. #8 Re: Stock exhaust question
    not at all. res and a glass pack are the same thing really. for 25 bucks its a cheap way to get a replacement on there.
  9. #9 Re: Stock exhaust question
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I will inject and say that it really depends on your mufflers. If you're running stock, then yes, it will be raspy. With borla mufflers and high flow cat/headers it's only a tiny tiny bit louder than stock you can barely hear it in the cab. Now, that being said, not sure how a supercharged engine differs from a n/a like mine, plus it's mainly stock... lol
  10. #10 Re: Stock exhaust question
    Donating User
    Jul 2014
    Minnesota
    Ok thanks for the help, also what is the outside diameter of the stock exhaust piping?
  11. #11 Re: Stock exhaust question
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    2.25"
    There's a list from last year about half way down - Resonators; Now with some part numbers
  12. #12 Re: Stock exhaust question
    Jul 2010
    Coquitlam,BC,Canada
    When I bought my car, the resonator was gone and stock mufflers were there. I had no drone and the tone was nice.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Replies: 1
    Last Post: 04-10-2013, 07:19 PM
  2. Question about stock exhaust manifolds.
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2011, 07:31 AM
  3. question on shining stock exhaust tips.
    By mezzoni in forum Visual/Body Modifications
    Last Post: 01-29-2010, 04:51 PM
