Messed around with it a little bit today, the fuse for the fuel injectors( believe it was B2) doesn’t have power with key on.(none of the fuses above it had power either they were all 15 amp fuses). Checked the connector at the pcm and going by the pinout I’ve found online, pin 4,5,6,7,10 all have power(not sure what voltage since I wasn’t able to use a multimeter only a test light/probe and the light was very dim) but pin 9 doesn’t seem to have any power which I believe is pin for the #2 fuel injector control. If all fuel injectors are powered by the same source which wire is it? Any diagrams?
