turbojimmy
Okay I fixed it today. It's a bad news, bad news, good news story.
Bad news is that after removing the old blend door actuator and manually rotating the door all the way to cool, it was still warm on the driver's side.
The other bad news is that the $20 replacement actuator motor I got directly from China was wrong anyway. Pins were different. I plugged it in anyway and it did nothing.
Good news is that the real problem was that it was low on refrigerant. Apparently the A/C system overcomes quite a bit of warm air that gets mixed into the air stream. It was 90 degrees out today and the passenger side was cool but not cold. On a hunch I hooked the gauges up to it. Pressures were low and there was evidence of ultraviolet leak detector in the system. It took 12 oz of r134a (all I had) and the pressures are close to where they should be. NOW the A/C is COLD cold on both driver and passenger side. I think the leak is the high pressure port which will suck to replace. I'll have to monitor it and see how quickly it leaks down.
