Thread: 2004 gp bcm
Results 1 to 4 of 4
  1. #1 2004 gp bcm
    Mar 2015
    Tampa, FL
    My reverse lamps stopped working a few months ago and now I wanna spend sometime and fix them. I think it's a Bcm issue, the fuse itself for CHMSL and back up lamps have power but no power to the back up lamps themselves. Tried to trace the wiring without compelty removing the interior. My EVIC says im in reverse so I don't think its a trans range sensor issue unless the back up lamps get signal from where else. When I view output data for the bcm on my scan tool for back up lamps on or off it always says off even in reverse. If it is a BCM, can a used be installed or are they VIN driven to the car. Its $45 for a used vs $250 for a new one. Anything else to try first?
  2. #2 Re: 2004 gp bcm
    open up the trunk lid harness where it goes into the trunk. very common for the wires to split, lic plate lights can also stop working as well.
  3. #3 Re: 2004 gp bcm
    Mar 2015
    Tampa, FL
    Thats all good. I have ground just no power. Probed the power wire at a point in front of the back seat and had no power. So either I have a break between the BCM and the rear seat, or the BCM driver is bad, or there is nothing else that provides a signal to acitvate the back up lamps
  4. #4 Re: 2004 gp bcm
    theres a small harness to the shiftier in the console, those wires like to break, the reverse lights might get activated from there.
  1. 2004 3.8 using oil
    By photomatt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2012, 02:38 PM
  2. Help please 2004 GTP
    By RageGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2011, 05:40 PM
  3. New HU in 2004 GP
    By GP04GT2 in forum Audio, Security & Visual Electronics
    Last Post: 12-31-2009, 01:04 PM
  4. 2004 GTP need help
    By trick94cobra in forum General Tech Discussion
    Last Post: 09-01-2009, 11:52 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
