Thread: Power Steering Pump Question
Results 1 to 6 of 6
  1. #1 Power Steering Pump Question
    TN
    2002 GP GT
    My power steering pump is whining loudly, especially until the car gets warmed-up, but still whines even after warm-up.
    There is no fluid loss and the fluid in it is not foamy. I have looked at it for a few weeks now.
    The steering is fine as far as I can tell and I see no leaks and the pump checks full. When I turn sharp it whines even LOUDER of course.
    It is a cheap aftermarket pump from autozone that I put on 5 or 6 years ago because the original one was leaking, but I have not had any issues until lately.
    The cap does not fit good and tight on it and never has.
    I thought that may be a problem, but the fluid is not foamy and it should have been a problem 5 years ago if the cap was the issue.
    I'm thinking to buy an AC Delco pump and replace, but I don't want to waste money if that's not it.
    Could the pump itself be bad if it is whining, even though the steering is fine?
    From all that I read, if the pump whines, it's low fluid or air in the system, but I have neither problem.
    I haven't read anything that says that the pump itself may be bad if it whines.
    I have also read that the fluid itself may be bad, but I just don't hardly believe that would be the issue.
    So, do yall think the pump is bad?
  2. #2 Re: Power Steering Pump Question
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by Hair View Post
    2002 GP GT
    Sounds like a bad pump to me. The autozone one may be a lifetime warranty. If it lasted 5 years I would just put another one of those on if its free. Flush out the lines to get all the fluid out, I'm sure it is contaminated with metal flakes. You could suck out the fluid in the reservoir and add some Lucas to try and quit it down and buy some time. You also have to worry about the metal in the fluid messing up the rack.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  3. #3 Re: Power Steering Pump Question
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I went through three Cardone remans (probably 99% chance Autozone is a Cardone reman) before I got tired of it and bought a new GM pump. First start with GM pump and zero noise. Been perfect since. Every one of the Cardone remans whined. The colder the weather the louder the whine. I had new lines, rack, tried various viscosity PS and trans fluids, etc. Nothing worked. Their rebuild job tolerances are not good enough.....
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  4. #4 Re: Power Steering Pump Question
    i got a duralast like 8 years ago, it was dead silent the day i installed it, and its still quiet. maybe i got the freak pump lol
  5. #5 Re: Power Steering Pump Question
    proof lol a year or so a go right after the is install.
  6. #6 Re: Power Steering Pump Question
    Banned
    Oct 2016
    Carroll, Ohio
    I can send you a good used GM (81k miles) for free if you pay shipping. It came off of a 97 I parted out awhile back. Also, I have like 7 good PS pumps on the shelf lol. I need to make shelf/storage space for a few more cars im parting out.
    Let me know if you want it, I can have it shipped Monday afternoon, as I'm already going to be at the post office sending off a few other packages.
    Sent from my SM-J327T1 using Tapatalk
  1. power steering pump
    By dgjks6 in forum General Tech Discussion
    Last Post: 09-20-2016, 10:20 PM
  2. Power steering pump
    By 05grndprix in forum Wanted To Buy - Parts
    Last Post: 03-19-2013, 12:28 AM
  3. '98 GTP power steering pump question
    By DrKavorkien in forum Introductions/Noob Questions
    Last Post: 08-31-2012, 10:50 PM
  4. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  5. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
