wheres the leak coming form on the pan? that pans rtv'ed on there, its not likely the leak, but the bolts could be the leaks.
if you got a dot of oil on every bolt, they leak, you can take them out one by one, clean the threads and then put new thread sealant on the threads and put it back in, these bolts only need to be snugged up good. and its only the bolts on the sides of the block that leak.
