Quote Originally Posted by rickisrad View Post
First make autozone refund your money for their crappy axles. Then go to Napa or Others have had luck with Orielly’s and get the axle. Make sure you are getting one for the Supercharged option. If at some point a transmission from a non supercharged was swapped in then you would need an axle from that if it is the right front (passenger side)
I second this. I had the same issue, went through four bands of axles before I went with napa remanufactured axles. Just make sure that you get the supercharged axle for the passenger side!
