Thread: 04 GTP questions, seeking mod advice
Results 1 to 20 of 32
  1. #1 04 GTP questions, seeking mod advice
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    Been lurking a long time, time for me to finally post. I picked up a 2004 GTP Competition Group about a month ago and have been doing maintenance and minor repairs in preparation to begin mods. It has 161k miles. I have a mod plan but would like a second opinion since I have the Series III motor and most advice on the web is for Series II. My budget is to stay under $1000, this is what I am thinking:
    -Exhaust work. Thinking ZZP front powerlog + 3" catted downpipe. I want full headers, but the only thing in my budget would be speed daddy headers and I don't have the skills to weld in a cat and figure out how to hook up the O2 sensor. Yes, I MUST have them because emissions are required where I am (Utah).
    -Canned PCM tune. I would like advice on which is best. From what I have read, people generally are happiest with Overkill and Intense tunes.
    -3.6 or 3.5 pulley, depending on how hard it will be to eliminate KR. I currently have 5-7* KR at WOT around 5000 rpm with engine warmed up and ambient temp of ~45 fahrenheit.
    I have already done gutted stock airbox and Autolite 104 copper plugs, as well as a mild shift kit. Tried to do 180 thermostat, but bolts are seized and I'm not interested in having to drill and tap new holes in my intake manifold after I break them.
    I only have access to 91 octane gas where I am, haven't seen any stations selling 92 or 93. No E85 either.
    So if anyone has any suggestions for different mods or how to make these work better, please let me know! I am new to modding and I can't do anything radical since this is my daily driver. I just want to have a few more ponies and make up for the lost performance from living at over 4000 feet of altitude lol
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #2 Re: 04 GTP questions, seeking mod advice
    Oct 2011
    Toledo, OH
    I wouldn't drop pulleys. I believe SD headers come with a V flange that clamps to the cat and to the flex, there should be no welding necessary.
    The thermostat bolts are deceptive. The actual bolt is like an M10 with an under sized head to prevent over torque.
    7"
  3. #3 Re: 04 GTP questions, seeking mod advice
    Oct 2011
    Toledo, OH
    Also, those plugs are too cold.
    7"
  4. #4 Re: 04 GTP questions, seeking mod advice
    Kemmerer, Wyoming
    I see no issue with autolite 104's. if you live in Orem you can get E85. We have a local group on Facebook that you could request to join if you wanted, it's somewhat active. Best bang for the buck in my opinion is an HP Tuner. you unlock so many options if you have your own tuner. it will eat up half your budget, but you have options once you have it. Speed Daddy headers are a good way to go. If you are interested in joining the local facebook group, send me a message and I'll get the request processed faster for you.
    https://www.facebook.com/marshal.corwin
    https://www.facebook.com/groups/530171857046278/
  5. #5 Re: 04 GTP questions, seeking mod advice
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SgtMarshal View Post
    They are 2 heat ranges below stock on a basically unmodified car. Too cold can result in carbon deposits on the tip that won't cook off during normal operation, which can cause a hot spot, resulting in KR...
    You want to run the hottest plug you can get away with.
  6. #6 Re: 04 GTP questions, seeking mod advice
    May 2008
    Schuyler, NE
    I doubt with the mods you listed that you'll be able to drop pulleys.
    Without access to e85, your biggest bang for the buck would be saving for a cam or intercooler. Actually, I'm pretty sure you could buy a downpipe, intercooler, and 3.4 pulley and still be under your $1000 limit.
  7. #7 Re: 04 GTP questions, seeking mod advice
    GTP Level Member
    Jun 2016
    Cleveland ohio
    You really need to get that 180 degree thermostat to continue further Mods. It will help with knock. You will never get an answer from Overkill on the PCM. I used a ZZP tune and hand no problems with them in my 04 gt and Comp g. I changed to an Overkill and it was better than ZZP setup wise. I have all of 04 Unlocked on my HPT if you want to work something out. Otherwise if I were you I would get an HP Tuner. You can do a lot with it and be able to get your car tuned properly. which in turn will give more power, better acceleration and shifts. As well as disable codes so it will pass inspection.
    Front plog would be ok but probably not needed unless you plan to mod further. You need to careful with a stock transmission as you mod.
    I would do-
    HP tuner or custom tune
    180* thermostat
    2.5 Downpipe.
    NGK TR55IX plugs- you can stick with the 104s if you wanted
    high flow air filter
    3.6 MPS if you really want to drop pulleys. Must be tuned well.
    Fuel pump rewire.
    Plog if cash flow permits.
    Having these things will allow you to mod in the future and have the tuning ability to do it properly.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  8. #8 Re: 04 GTP questions, seeking mod advice
    May 2017
    Dirtyzville, Mizzery
    Quote Originally Posted by industrialfish View Post
    True; however if you can run the colder plug (like I did), it isn't hurting anything.
    Hell I had over 20k~ miles on AL103's and everyone always likes to complain that there isn't any life in them.
    Run the 104's; gap them @ .050". Enjoy.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  9. #9 Re: 04 GTP questions, seeking mod advice
    Nov 2017
    Utah
    Thanks for all the replies!
    If my 104s start giving me problems, I'll switch to TR55s or something similar.
    So I'm seeing recommendations for HPTuners. What's the best place to get it? I have zero experience with tuning, but I'm decent with computers and I'd try to learn if it's worth the cost in my budget. Then I could go the E85 route if I can find it around here. That requires new injectors and a fuel pump, correct? Then I could drop a pulley size?
    I also like the idea of intercooling, but I figured it would be just out of my price range. Has anybody had experience with piecing together a kit? ZZPs kit is too much for me, I'd have no money for other mods.
    I really just want a decent increase in performance for my budget because I don't think I'll mod much after the first $1000.
  10. #10 Re: 04 GTP questions, seeking mod advice
    May 2017
    Hah; I'm probably not the best person to reply on that but I ran a totally stock fuel system on E85. Only thing I had done was the tuning (By Reptile), a couple fuel filter changes to make sure there wasn't anything clogging up since the car had over 280k on it, and lastly just green top Ford injectors (42lb.). Was a '98 GTP with a 3.2", GenV, Ported L67 TB, 3" catless DP, Open Cone intake, bone stock everything else.
    As for putting together a kit, I'd venture to say that the E85 would be better than the intercooler, but that's me.
    You'd be pretty well off tuning, pulley drop with headers, and springs/rockers. That'll toss your car right around 260-270WHP with say, a 3.5"/exhaust/rockers. E85 should put you in the 3.25"~ area...cranking timing as well...I'd say close to 300 at that point. These however are torque motors...they're not gonna grab your junk on a horsepower rating. It's pretty depressing most of the time.
  11. #11 Re: 04 GTP questions, seeking mod advice
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by blueguy91 View Post
    I forgot about the rockers. Those are probably the best bang for your buck, other than a cam!! If you go E85 make sure you have a Tuner. I had issues with an E85 setup but it turned out to be a pcm going bad. I would contemplate doing it again but the fuel filter on the 07 is internal. The best bet for buying HPtuners is look at the HPT forums and look for someone that offers free training or support. Otherwise any vendor is ok. There are also some basics in the Tuning section to get you started.
    *** I just read you dont have e85 option so forget those suggestions. lol
    BTW. I will put a shameless plug here. I have a basically new AC Delco fuel pump for the comp g if you ever need one.
  12. #12 Re: 04 GTP questions, seeking mod advice
    Kemmerer, Wyoming
    what part of Utah are you from?
  13. #13 Re: 04 GTP questions, seeking mod advice
    Nov 2017
    Utah
    I'm in Orem, so since you mentioned there is E85 there it opens up possibilities for me.
  14. #14 Re: 04 GTP questions, seeking mod advice
    Nov 2017
    Utah
    So E85 would need injectors, a tune, maybe a fuel filter, and I could drop to what pulley size? 3.4 with no other mods? Would I need exhaust work?
  15. #15 Re: 04 GTP questions, seeking mod advice
    Kemmerer, Wyoming
    you should message me on facebook
  16. #16 Re: 04 GTP questions, seeking mod advice
    GTP Level Member
    Jun 2016
    Cleveland ohio
    yes you need at least 42# injectors and if plan any further mods 60#. You will need a fuel filter. change it after a week of running the E85. You shouldn't need exhaust work. Downpipe helps. 180* thermostat, smaller gap on plugs, with no other mods I would think 3.6 maybe 3.5 with a proper tune.
  17. #17 Re: 04 GTP questions, seeking mod advice
    Nov 2017
    Utah
    Okay, thanks for the help everyone. It was very insightful! I'll go do some research and start pricing out parts to see what works best for me.
  18. #18 Re: 04 GTP questions, seeking mod advice
    Jun 2016
    Baltimore
    Quote Originally Posted by derpyimp View Post
    I had similar KR on my car, bone stock except shift kit. ZZP plogs + their 3" dp dropped it down to < 2'. The 180 thermostat didn't really seem to help KR on my car nor did 1 range colder plugs. I'm considering getting their 1.9 rockers today since they're on sale to try to eliminate KR entirely, but not sure if it's worth it.
  19. #19 Re: 04 GTP questions, seeking mod advice
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by rickisrad View Post
    Overkill Motorsports doe not do 3800 canned tunes anymore anyhow. The only way your going to get a tune from Overkill is by buying HP tuners through him and he will set you up with a base tune then you need to send him scans so he can help and essentially get you on the road to tuning it yourself.
  20. #20 Re: 04 GTP questions, seeking mod advice
    May 2017
    I'd recommend exhaust work on ANY 3800...of any level of modding.
    It's god awful. The catback is fine; but everything else needs help. Manifold casting is crap, the downpipe is tiny, and the U-Bend is even worse.
    On a stock car, PEM's and a 3" downpipe would probably add 15-20~ horse...and most of that would just be killing all the KR.
  1. Throttle Body Cleaning--Seeking advice
    By Mr D in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2014, 01:17 PM
  2. Seeking advice on rear wheel bearing
    By Exile in forum General Tech Discussion
    Last Post: 12-22-2013, 12:39 AM
  3. Seeking leagal advice in an accident/hit&run
    By Prixer97 in forum General Grand Prix Discussion
    Last Post: 05-01-2013, 10:29 PM
  4. New Car and Preservation Concerns (seeking advice)
    By younger5th in forum General Grand Prix Discussion
    Last Post: 04-03-2013, 07:02 PM
  5. Seeking Advice about Lowering Springs/Rims
    By mRa in forum Visual/Body Modifications
    Last Post: 04-10-2010, 11:55 PM
