wstefan20
Yup! My machine shop found out that you can plane off both intersecting halves of the connecting rods to bring it back into round, and if done right, it brings clearances back at the same time without having to re-grind your crank or use different sized bearings! Worked like a charm! Then I just used the re-usable ARP bolts to add some strength.
When you go to swap cams, I'm sure you might already know this, but if you drop the subframe just right, you can get this sucker out through the wheel-well and not worry about pulling the whole engine. You do need to unbolt the exhaust and a few other things to avoid damage, but then I just remove timing cover and have some fun! I'm not a big fan of the janky way of using the starter to spin off the crank bolt. I just use a long breaker bar and put a chisel in the flywheel teeth by the inspection cover taped to a stand so I don't have to hold it. Use this trick at the junkyard all the time and it works like a charm. Same thing for torquing it back down too! I use an old timing chain and sprocket for the cam bolt in the off chance that I stretch the chain or break the tensioner. I'm probably too cautious though in some regards. I've messed with this engine a little too much... haha
