Thread: Powerlogs
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Powerlogs
    Donating User
    Jul 2014
    Minnesota
    I did not know about that part, are there instructions somewhere?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #22 Re: Powerlogs
    Donating User
    Jul 2014
    Minnesota
    Also, can the rear headers be installed without pulling the motor forward?
  3. #23 Re: Powerlogs
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I'm sure there's some sort of a instructional out there, but there's really no need. all pulling the engine forward entails is removing both dogbone bolts and taking a ratchet strap to gently pull the engine forward. I'm sure it's possible without doing that, but you'll need to remove the dogbones for the front manifold anyways, so why not? You'll need to remove your intake if you still have stock box for room, then just remove the crossover, various engine braces and then bolts for headers and off they come! Use plenty of penetrating oil and you'll be ok. I let everything soak in it before I get started. You'll want to remove spark plugs of course. There's other things you can remove if you want to make things easier. Really isn't that bad of a job, I've done a few of them. I usually alternate between swearing and laying on the engine from up top, and using a long extension from below and swearing some more for the rear. Front is a cake walk.
  4. #24 Re: Powerlogs
    Donating User
    Jul 2014
    Minnesota
    Ya ive done the ratchet strap before when i did the rear valve cover gasket on my last GP. Good thing I just did my plugs and wires so I know they will come out easy. So the Speed Daddy kit comes with a DP correct?
  5. #25 Re: Powerlogs
    Aug 2017
    Raytown, MO
    Yes it does. Has the option for running straight pipe, or catalytic converter. I picked up a 3" high flow ss cat and strapped it in for around $50. It'll throw P0420 till you tune it out or you can use a 02 spacer (aka spark plug non-fouler drilled out).
  6. #26 Re: Powerlogs
    Donating User
    Jul 2014
    Minnesota
    Can I have my ZZP tuned PCM tune this code out?
  7. #27 Re: Powerlogs
    Aug 2017
    Raytown, MO
    You'd have to ask zzp, but I'd assume so. My car passes emissions no problem but the pcm doesn't like the readings, probably because it's flowing more exhaust. Gives the car a really nice sound too.
  8. #28 Re: Powerlogs
    Donating User
    Jul 2014
    Minnesota
    My state doesn't do emissions test, ill ask ZZP
  1. Powerlogs at zzp black friday sale?
    By 04CompG in forum Off Topic Discussion
    Last Post: 12-02-2008, 12:09 AM
