Thread: So this is odd...
Results 1 to 10 of 10
  1. #1 So this is odd...
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I was in park and was listening to the engine after work today. Well as i was reving engine, at about 3k rpm maybe a tad more i tried to give it more gas. Well nothing happened. I tried again. So at around 3k no matter how much gas i give it it will not go any higher. No when I drive it seems normal so im thinking maybe a safety feature??? Or maybe something in the POS ZZP PCM. God I cant wait till i recieve Will's. Anyways anyone heard of this?
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: So this is odd...
  3. #3 Re: So this is odd...
    Barksdale AFB, LA
    Stock rev limiter is 4k. Maybe ZZP lowered it to 3k?
    2009 Subaru Impreza WRX STI
  4. #4 Re: So this is odd...
    Feb 2008
    Nashville
    I thought about that but it didnt bounce like a rev limiter would. Just as if there is no more pedal lol. Either way this makes me feel better. ty
  5. #5 Re: So this is odd...
    Charles City, IA
    I think neutral is 4k and park is 3k. Not sure tho.
    SMGPFC Two Nipple General
  6. #6 Re: So this is odd...
    Feb 2008
    Nashville
    Hmmm I feel a test coming on!
  7. #7 Re: So this is odd...
    TDCRacing
    Guest
    They use the electronic throttle as the limiter. That is why it does not sound like a convential rev limiter. With the 04+ they can limit throttle movement instead of limiting fuel and spark for the arlier models that had a cable operated throttle.
  8. #8 Re: So this is odd...
    TDCRacing
    Guest
    4005.-P/N
    4000.-Reverse
    6000.-In gear
  9. #9 Re: So this is odd...
    not a bad limiter to have honestly!
  10. #10 Re: So this is odd...
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    I had no idea..... im defiantly going to try that in the morning now.
odd
