Thread: Help with ground points.
Results 1 to 11 of 11
  1. #1 Re: Help with ground points.
    how about we start with whats wrong with your car?
  2. #2 Re: Help with ground points.
    SE Level Member ELECTRICxWIZARDx's Avatar
    Sep 2017
    SW Oklahoma
    headlight switch not illuminating, dic flickers, window motors/door locks are slow and dim all lights. keyless not working.
    sunroof motor does not like cold. near non-functional, last night, trying to open it kept resetting the rearview mirror since it was bogging down power so bad. I suspect a bad ground as when i first got the car, the domes would stay on when fuse was put back, which turned out to be something loose in the switch panel for the sunroof.
    p/o has run a wire from i/p drl fuse to brwn turn signal wire. I'd like to remove this, and troubleshoot it back to factory. looking at wiring diagrams, this looks like a pretty major circuit. Ties into s204 brwn.
    Between here & reddit, redoing grounds has been suggested, don't want to miss any. freshening up the underhood grounds seemed to help smooth out running and brighten headlights.
    Black 2001 GTP Sedan
    Bone stock... for now.
    Save the Pontiacs!
  1. shift points
    By roadhawg in forum Introductions/Noob Questions
    Last Post: 08-08-2013, 12:59 PM
  2. Jacking points
    By Madness in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2012, 11:15 AM
  3. lift points
    By gtp99 in forum General Tech Discussion
    Last Post: 08-14-2012, 11:15 AM
  4. Shift points and Mph?
    By GTP4 in forum PCM Tuning
    Last Post: 11-11-2009, 12:59 PM
  5. Rep points vanished ???
    Last Post: 11-03-2008, 05:43 PM
