Thread: Need to Buy a Hub, Which Brand?
Results 1 to 17 of 17
  1. #1 Need to Buy a Hub, Which Brand?
    Apr 2014
    Utah
    My 04 GTP has all the brake warnings, bad LF wheel speed sensor. Rockauto has these brands. Should I stay away from any?
    Centric, GMB, WJB, Mevotech are cheaper but are they any good?
    I recognize Raybestos, Timkin, ACDelco, SKF but price goes up.
    Which one would you get?
  2. #2 Re: Need to Buy a Hub, Which Brand?
    add moog to the good list and get one of those, they all got a 3 year warranty and do go bad. but not as fast as the cheapos.
  3. #3 Re: Need to Buy a Hub, Which Brand?
    St. Louis
    Timkin or SKF. The Timken is only $85.79 and if you search you can probably find a discount code which may drop it a bit more. I run only Timken or SKF bearings in my GP and they have never let me down. Just make sure you torque the hub nut to the proper setting and you're good to go.
    *edit* Forgot about the Moog's. Those are good quality as well. Another option if they are the most affordable.
  4. #4 Re: Need to Buy a Hub, Which Brand?
    Quincy, Mass
    I go with timken for years, didn’t like the moog hubs when I used them, didn’t last long for me. Never had a problem with timken
    No more GP 04 Impala SS Indy:
  5. #5 Re: Need to Buy a Hub, Which Brand?
    SE Level Member GrandPrixGT1's Avatar
    Jan 2017
    Mount Airy, MD
    I’d honestly go with GM ACDelco. I try and keep non go fast parts OE replacement parts.
  6. #6 Re: Need to Buy a Hub, Which Brand?
    Apr 2014
    Utah
    Thanks for the advice guys. I'll get shopping.
  7. #7 Re: Need to Buy a Hub, Which Brand?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Do not do mevotech anything. I've had issues with all their parts. GMB is decent but wont last. Moog or Timken is the best I've used
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  8. #8 Re: Need to Buy a Hub, Which Brand?
    GTP Level Member buickman104's Avatar
    NYC
    I second on Mevotech being terrible quality!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: Need to Buy a Hub, Which Brand?
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Quote Originally Posted by buickman104 View Post
    Mevohorny!
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  10. #10 Re: Need to Buy a Hub, Which Brand?
    Jan 2014
    AR
    Quote Originally Posted by born2pdl View Post
    I have two 99s and there are "Precision" brand hubs from O'Reilly's on 7 of those 8 wheels. I have not had trouble with them but don't know who makes them. $125, yellow box with blue writing.
  11. #11 Re: Need to Buy a Hub, Which Brand?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by idrivejunk View Post
    You can can get a Timken for $40 cheaper on rock auto!!!
  12. #12 Re: Need to Buy a Hub, Which Brand?
    Jan 2014
    AR
    Quote Originally Posted by rickisrad View Post
    I can't walk into rockauto.
  13. #13 Re: Need to Buy a Hub, Which Brand?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Ive heard that timeken and SKF can be expected to go for a long while.
    Moog are ok. Last about their warranty period.
    The others die quick and are not worth the money.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  14. #14 Re: Need to Buy a Hub, Which Brand?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I replaced both my fronts with Timken almost 7 years ago. Zero issues so far.
  15. #15 Re: Need to Buy a Hub, Which Brand?
    Jul 2016
    St. Louis
    I have good luck with used low mileage OEM. The bad news is low mileage stuff is becoming hard to locate any more. Good news is you can use a hub off an Impala all the way up to 2014 model year I believe. I picked one off an 09 Impala at a local pick n pull for $15.00.
  16. #16 Re: Need to Buy a Hub, Which Brand?
    Jul 2010
    Coquitlam,BC,Canada
    They all suck. I've had my car for 8 years now and had to replace the front bearings 7 times (4 on the right front, 3 on the left front). I started using SKF, but have switched to Delco because up here, the Delco has a 5 year warranty.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Need to Buy a Hub, Which Brand?
    SWPA
    I put Moogs in mine several years ago and they were still in it when I sold the car earlier this year.
  1. Brand new zzp hub
    By Rlugo87 in forum For Sale - Parts
    Last Post: 10-16-2017, 09:32 PM
  2. L26 HV3 Brand New!
    By Swiggles in forum For Sale - Parts
    Last Post: 08-27-2016, 05:01 PM
  3. MAF brand?
    By shedawg in forum Shops and Community Heroes
    Last Post: 06-26-2014, 04:29 PM
  4. Replies: 0
    Last Post: 07-29-2013, 07:17 PM
