Thread: Where does this bracket go?
Results 1 to 20 of 28
  1. #1 Where does this bracket go?
    Nov 2014
    Macon, GA
  2. #2 Re: Where does this bracket go?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Pics won't load for me
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  3. #3 Re: Where does this bracket go?
  4. #4 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    It is off a 2006; supercharged.
    It looks like it fits into a hole, just hope someone can answer.
  5. #5 Re: Where does this bracket go?
    im gonna go out on a limb here, its not from your car. and if it is, you didnt need it anyways lol.
  6. #6 Re: Where does this bracket go?
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    ^^ that. Or, looks like it could be from the inside of the car. From somewhere under the dash. That was my first thought. Looks like it's meant to swivel back and forth and has a stopper on that one side to prevent it from going too far...
  7. #7 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    I am 100% sure it came from the car, maybe somewhere in the starter / transmission area? possibly?
    Really it could be from anywhere under the hood, as I had th eengien and transmission out, then split and , re-mated.
  8. #8 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    I think the one hole might be for a push-dart, maybe in the power steering area?
  9. #9 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    And for the reward, of viewing this thread > https://imgur.com/gallery/EVsshbd
    Just wait for it.
  10. #10 Re: Where does this bracket go?
    Oct 2011
    Toledo, OH
    It's impossible to get a good picture of it. Power Steering bracket. Below and between cylinders 2&4 attached to the transmission or block.
    Where does this bracket go? Attached Images
    7"
  11. #11 Re: Where does this bracket go?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    whatever it is it is not required because I left mine off because I couldn't find out where it went. LOL. My 04 didn't have it so I figured it was just a worthless bracket.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  12. #12 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    Interesting, that does seem to be it, I wonder if this is it in this pictures> https://imgur.com/NOOqwB5
  13. #13 Re: Where does this bracket go?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by grinditout View Post
    I don't think it's the piece in the center of your circle. My pic is almost direct top down. So past the #2 boot.
    7"
  14. #14 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    I figure, I can set up the dart, as I know where it goes then see where the bracket lands, although, I am curios which bolt/nut is the right one.
  15. #15 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    Luckily, it have several vehicles, and this one has turned into a leisure thing.
  16. #16 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    Reach down there and shoot some more pictures?
  17. #17 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    Surely you need to pull that spar plug, for some reason.
  18. #18 Re: Where does this bracket go?
    Oct 2011
    Toledo, OH
    Yeah I'll try to get a better angle tomorrow when it's not raining.
  19. #19 Re: Where does this bracket go?
    Oct 2011
    Toledo, OH
    Also my tab has grease on it so it's black, kinda throws visuals off.
    7"
  20. #20 Re: Where does this bracket go?
    Nov 2014
    Macon, GA
    Ok, I see several things going on there, it looks like it is sitting on a stud, with a nut then the power steering pressure side hose, has a dart, then the wiring harness has a tab, that goes int the bottom of the dart, after the bracket.
    Sound right?
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. Name this bracket.... Thanks
    Last Post: 10-21-2009, 07:23 AM
