Thread: 2004 GPGT P0341 error code
Results 1 to 13 of 13
  1. #1 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    Crank Pos. Sensor..Had it replaced and error code does not go away..mechanic says its some magnet on the timing chain and that replacing it is the only way to fix this...Major engine work to the tune of at least $1000..so this mechanic says...Car does run rough at idle sometimes and will stall from running but it does run good everywhere else...I had to get a waiver for inspection in the state of NC...so what is the truth here?
    Also ABS..Traction control and Tire Pressure warning lights are also on..
    Do I need major engine work to fix the P0341 code?
    Also got a P0301 CYL1 misfire....???
  2. #2 Re: 2004 GPGT P0341 error code
    Oct 2011
    Toledo, OH
    I'm guessing you need a CASE relearn.
    Crank Angle Sensor Error.
    7"
  3. #3 Re: 2004 GPGT P0341 error code
    Oct 2011
    Toledo, OH
    Nevermind. P0341 is CAMshaft error, not CRANKshaft.
    Did they replace the wrong sensor?
    7"
  4. #4 Re: 2004 GPGT P0341 error code
    if you changed it already, id try changing the crank/ cam to icm harness. that thing tends to get worn out. some how the insulation gets beaten off the wires, then you get a low circuit.
    its not to hard to remove really. crank plug is the hardest, you need to use a pick through the plastic cover behind the balancer, takes a creative looking at.
  5. #5 Re: 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    Quote Originally Posted by industrialfish View Post
    oops my bad..my vision sucks with cataracts..anyways sounds like no one is saying anything about going into the engine to replace some magnet thingy....zI will try your suggestions..Thanks
  6. #6 Re: 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    did you mean ECM harness?
  7. #7 Re: 2004 GPGT P0341 error code
    no. just like i stated, cam/crank, to icm. its the short harness the cam and crank sensor plug into, it plugs into a square plug near the front v/c and the icm iirc.
    the damage to mine.
  8. #8 Re: 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    Just rechecked..P0341 is Crank Pos.Sensor A Bank 1 CKT Range/Performance..Thats what is listed in the code book ......
  9. #9 Re: 2004 GPGT P0341 error code
    that bad harness gave me 3 codes, and made my fuel pump quit. worth a shot to take it out and look it over.
    A code P0341 may mean that one or more of the following has happened: Cam sensor wiring routed too close to spark plug wiring (causing interference) Poor wiring connection at cam sensor Poor wiring connection at PCM Bad cam sensor Damaged reluctor wheel
    Read more at: https://www.obd-codes.com/p0341
    Copyright OBD-Codes.com
  10. #10 Re: 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    Thankyou..appreciate your insights nd suggestions..We will be looking closely at that harness..my only other error code is P0301 Cyl 1 Misfire detected
  11. #11 Re: 2004 GPGT P0341 error code
    how are the plug wires routed? they near the harness at all? might be connected.
  12. #12 Re: 2004 GPGT P0341 error code
    Oct 2011
    Toledo, OH
    Quote Originally Posted by stbne View Post
    Dunno what book you are referring to, but it IS Cam sensor code, not Crank. So again, did they replace the wrong sensor?
    7"
  13. #13 Re: 2004 GPGT P0341 error code
    Oct 2013
    Wendell NC
    Just checked my paperwork and the mechanic changed the Cam Sensor...so why the confusion in term..IDK.I have my own OBD2 reader ..and the DTCs are 8n the uswrs manual..perhaps thats where the error is???
  1. Engine Swap and now getting code P0341 andP0107
    By nd48463 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2014, 12:26 PM
  2. error code
    By fran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 06:28 PM
  3. 2004 GPGT in the 14's
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 07:54 AM
  4. Error codes p0341 and po300
    By jessiinicole in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 04:34 PM
  5. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
